Your Testosterone Estrogen Ratio
Remember those chem lab days.  Well, if you do, you may remember that sometimes the concentration of a solvent or chemical is more important than the absolute amount of the same.  What I remember even more is getting kicked solidly in the right buttock by my 8th grade chem teacher for goofing around with chemicals in the laboratory, but that's another story.
Again, though, the concentration is often critical and this hold true in the hormonal world as well.  For example, researchers recently found that it is the ratio of testosterone to estrogen that determines prostate cancer health more than total testosterone.
So what is a good T/E ratio?  A solid number for a 20 year old male is 30-40 with some guys shooting near 50.  Of course, some would argue that a T/E ratio that high makes it to where most guys can't think straight.  Regardless, youthful testosterone-to-estrogen ratios are quite high and are certainly ideal in terms of maintaining male health. A healthy, youthful testosterone/estrogen ratio is about 50:1
Of course, the problem is that guys, as they age, find this all-important testosterone to estrogen ratio steadily decreasing to sometimes even the single digits. The situation seems hopeless because all males find their testosterone simultaneously decreasing and their estrogen increasing.  This is assaulting our T/E fraction in both numerator and denominator:  you've got the numerator decreasing while the denominator is increasing.  Quite the "double whammy", eh?
What causes these rapid changes on both top and bottom in the negative direction.  Well, some of it is aging.  Males just naturally lose a little testosterone as they age due to mitochondrial dysfunction, DNA and oxidative damage and so on.  However, one of the greatest culprits is the extra pounds around our middle. Extra fat pumps out more aromatase which in turn pumps out more estrogen into our system.
That creates a viscious cycle because the extra estrogen will "crowd out" testosterone and lower the body's testosterone output.  Then, as testosterone is lowered, muscle is lost and as muscle is lost, fatty tissue is increased and so on.
Is there any good news in all of this?  Yes, the same "double whammy" that lowers our T/E ratio can also raise it.
As an example, let's look at an eye-opening Cialis study.  Of course, Cialis is the 36-hour PDE5 inhibitor that has put so many middle-aged and beyond guys back in the game.  And getting back into the game has a profound effect for most much guys:  it boosts  their testosterone to estrogen ratio by 24% on average according to one study. [1]
The reason?  Cialis gives guys who are struggling confidence and that all-important Nitric Oxide boost that leads to more sex.  And more sex boosts testosterone and a host of other changes.  What is interesting is that in the above study, testosterone only increased 5.5% on average but estrogen lowered by about 15%.  And the net boost in the T/E ratio exceed the sum of those two by a few percentage points as well.
Now this is a remarkable change if you think about it.  The "concentration" of testosterone and estrogen - estradiol is what really counts - changed by 24% from just one lifestyle change.  Imagine what could happen as you pile on some of the other Testosterone Increasing Techniques and Estrogen Lowering Strategies that I have mentioned on the web site.  There is no reason that you cannot dramatically improve your ratio of testosterone to estradiol (unless you happen to be training for the Olympics with a professional trainer).
If you think I am exagerrating, then consider another study of guys with fertility problems.  These were relatively young guys within a decade on either side of the average age of 39.  They split them up into two groups: those with a BMI > 25 and those with a BMI less than 25.  The difference in testosterone-to-estrogen ratios was signficantly different:  12 versus 17.  That is a 42% difference!
Does this make sense that body fat would make such a significant difference in the T/E ratio?  Remember that the more fat, the more aromatase and the more aromatase the more estrogen and the more estrogen, the less testosterone.  Excess body weight is correlated with both lowered testosterone and increased estrogen.  In other words, being overweight will hit both sides of the fraction negatively.
By the way, this may explain why weight lifting has been associated with increased long term testosterone levels.  Weight will increase muscle mass and "muscle burns fat".  Adding muscle, however you do it, will actually change your metabolism for the better so that the same calories go farther.
The point is that, generally through the very natural strategies that I list on this site, you will very likely be able to make a very substantial change to your testosterone/estrogen ratio and, as a consequence, feel a hundred times better and lower your risk for many diseases and conditions.
CAUTION:  Most guys probably do not know that caffeine increases both cortisol AND testosterone.  Unfortunately, it does not raise testosterone enough proportionately thus lowering the overall testosterone-to-estrogen ratio. [3]
REFERENCES:
1) The Journal of Sexual Medicine, Jul 2006, 3(4):716-722, "Testosterone:Estradiol Ratio Changes Associated with Long-Term Tadalafil Administration: A Pilot Study"
2) Systems Biology in Reproductive Medicine, 2006, 52(2):97-102, " Effect of bodyweight on testosterone-estradiol ratio in oligozoospermic patients"
3) Int J Sport Nutr Exerc Metab, 2008 Apr, 18(2):131-41, "Dose effect of caffeine on testosterone and cortisol responses to resistance exercise"
