PRIMOBOLAN (Methenolone Enanthate)
If ever there was a steroid that can be considered “perfect” (or as perfect as can be), it would be Primobolan. It’s considered to be the safest and least suppressive anabolic steroid, has few side effects and is extremely effective. So why isn’t Primobolan used by everybody? The reasons may lie in many of the misconceptions surrounding this incredible drug.
Primobolan does not give fast gains, or more accurately, does not cause a quick increase in water retention, therefore it’s considered “weak”, yet in terms of building solid muscle, it’s one of the most effective steroids available. Because Primolan has little to no side-effects it is also used by older athletes and females. This also ruins its reputation amoung hardcore bodybuilders. Primobolan comes in a low dose mostly 100 mg/ml and isn’t cheap. It was also one of the most counterfeited steroids and then the active ingredient Was mostly a low dose of deca (around 20 mg/ml). This was also often the case with many UG products. And I always meet guys that honestly believe that the high dosages on the label compare to the real content. Primobolan is a very expensive compound to buy , the API (raw powder) costs around 14.000 euro. Even then you have to wonder what the quality of that API is. Luckely we have the ability to analyse. What also was feeding Primobolans bad reputation of being weak and expensive is the fact that (just like Growth Hormone) you have to use it for a considerable cycle length, 18 weeks at least and if possible even longer then 20 weeks. And at least 800 mg/week, because it is so mild you can easily use over 1 gram per week of it and not have any issues with bloating - destruction of your lipids - thicker blood etc.
Pro-bodybuilders value its ability to maintain muscle while in a caloric deficit during cutting or contest preparation. This is not new Arnold was known to love Priomobolan and Dianabol (the breakfast of the Champions). We’ll post the cycle beneath and a recent cycle (2012) of 2 IFBB bodybuilders. Of couse we will get questions on how we know. We provided them their gear, capiche?
All steroids are based on the testosterone molecule and all steroids provide two functions – one, of mimicking androgenic effects within the body. (Basically all “male” attributes – strength, aggression, the ability to grow muscle, etc). And there’s also the “anabolic” effect, in that they recirculate nitrogen (protein) therefore utilizing more of the necessary building blocks needed for tissue growth and repair. Unless sufficient amino acids are present muscle growth will be sub par and in the case of Primobolan this is of utmost significance. You MUST train hard and you MUST eat a lot of protein. THAT, is when you’ll see what Primobolan can do.
The concept behind Primobolan was to have a far greater anabolic to androgenic ratio. The reasoning is not far removed from the original steroid Dianabol, which was formulated to be a “kinder, gentler” form of testosterone. In this way, the athlete can get all the benefits of greater muscle growth without all the detriment and suppression of excess androgens. In the case of Dianabol, it was a good idea yet just it didn’t turn out quite as well as expected. With Primobolan, they got it right.
This is Arnold' Schwarzeneggers 26 week cycle of Primo, D-bol and Deca from 1984. The layout did not list any testosterone, which I believe should be included, but Arnold's cycle obviously worked wonders combined with his genetics, diet and training. Nor is it believed he did took an AI and he didn't do PCT for the mere fact that he did not actually come off but instead "cruised" on lower doses of Dianabolbol and Deca. I've done Primo, Dbol and Deca but never as laid out in a lengthy and high dose cycle such as the one Arnold apparently did.
Blast
Weeks 1-5
Primo 600mg EW
Dbol 60mg ED
Weeks 6-10
Primo 800mg EW
Dbol 80mg ED
Weeks 11-14
Primo 1000mg EW
Dbol 100mg ED
Weeks 15-17
Primo 800mg EW
Dbol 80mg ED
Weeks 18-20
Primo 600mg EW
Dbol 60mg ED
"Cruise"
Weeks 21-26
Dbol 30mg ED
Deca 200mg EW
Note: No Test, No AI and No PCT
Then, repeat above cycle
IFBB PRO STACK
stack will be simple, 10iu Hygetropin per day, 500mg Test enan per week,
1400mg methenolone enanthate per week and 1000mg drostaneolone enanthate per
week more or less. do you think if I add the MT-DMN that there will be issues
with water retention and gyno? nurtrition is spot on and low carb with 1-2 high
carb days per week.
could you get me letrozole and cabergoline and drop the bromocrypine? i believe
cabergoline is way more effective in surpressing the prolactin and has less
sides.
Both guys also used MT-DMN and gave a good feedback
Being a DHT derivative (technically it’s DHB) Primobolan blocks SHBG (sex hormone binding globulin) thus preventing estrogen from forming. None of those compounds bind the progesterone receptor.When using Primobolan you’re not only don’t need to add an anti aromatase it acts as one on its own, so if even if you add testosterone, an anti-estrogen may not be required. Theoreticly this cycle wouldn’t not raise prolactin still the bodybuilders took cabergoline, I don’t know for what reason.
.jpg)
