Parabolan (trenbolone cyclohexylmethylcarbonate)
Parabolin is an injectable steroid which contains 100mg per ML of the hormone trenbolone hexahydrobenzylcarbonate. This is the same hormone/ester combination that the legendary Parabolan consisted of which was first developed in the late 1960s. This ester is very similar to enanthate as far as time realease schedule into the body. This is the only form of the hormone trenbolone that was ever produced by pharmaceutical companies for human consumption. Users typically find a twice weekly dosage regime to be sufficient in keeping steady blood levels.
Trenbolone is considered to be one of the most power steroids in use today. Tren, as it is often called, is both highly androgenic and anabolic. It is chemically unable to aromatize, and therefore produces no estrogen buildup. This, along with its high androgenic properties, makes the muscle produced by this drug very hard and defined. Trenbolone first got its reputation when it was used in this legendary steroid.Users of this drug often noted dramatic results that were nothing short of amazing, and after it was unfortunately discontinued, the remembered effects of the substance gave it cult like status and the market was flooded with bunk Parabolan amps by those looking to profit off the extreme popularity and fan base that this steriods incredible results had sparked. Trenbolone was also used in cattle implant pellets, where the substance was used to increase the lean mass of the cattle, while reducing the fat on the animals. Kits became widely available on the internet allowing bodybuilders to convert these pellets into injectable solution. Fina, as this homebrew oil was often called, quickly became a favorite of steroid users, like its relative, Parabolan, had done many years before. Users of parabolin often report amazing gains in both strength and quality muscle mass, while the fat and water seems to "melt" off. To give one an idea of just how powerful this hormone is as a muscle builder, please note that the powerful steroid Testosterone has an anabolic rating of 100, while this drug has a rating of 500! The drug is also a powerful fat burning aid, and lots of bodybuilders actually claim that the body will still drop bodyfat very quickly, even when ones diet isnt very clean. It is important to note that this substance will shut ones natural testosterone production down very quickly, thus making a proper PCT protocol a must upon conclusion of a cycle. Tren is a very androgenic compound and can produce all common androgenic side effects. Its also important to note that many users report uncontrollable night sweats while using this substance. To help combat this problem, its recommended that users try to keep blood levels and stable as possible, and stay in a reasonable dosage range. Although this steroid cant convert to estrogen, some users do experience problems with progesterone related side effects, similar to those seen with products such as Deca Durabolin or Durabolin. Users sensitive to these issues may prefer to add Cabaser to their cycles. Trenbolone can be used in both cutting and bulking cycles. Those looking to bulk might add an injectable form of Testosterone along with an oral such as Methandrostenolone. The famous Tren /Test Propionate/ Winstrol stack is still regarded as one of the best cutting/ pre-contest combinations that there has ever been. This cycle, along with proper diet and cardio, is sure to bring about results that are extremely dramatic.
The typical dosage range for men taking this drug is 300-700mgs a week for a period of 6-10 weeks. Women should avoid this drug due to its very strong tendency to produce androgen related side effects in users.
