Megagrisevit Mono (clostebol acetate)
Clostebol acetate is an anabolic steroid that is a derivative of testosterone. Clostebol is 4-chloro-testosterone, a modification that makes this drug a low strength anabolic compound with minimal androgenic potency. Clostebol acetate was first produced in 1956 and was developed into a prescription medication in Europe where it was marketed under the name Steranabol by the company Farmitalia, and the name Turinabol by a company called Jenapharm. The original medical use for this product was to treat osteoporosis, and then later was found to be successful when used to treat conditions of anorexia and certain types of liver disease. Clostebol acetate was made in both the form of oral pills and also an injectable preparation. This drug was widely used with females and elderly patients due to the mild anabolic nature of it. Although quite favorable in effect and the comfort of use, clostebol acetate was never really successful as an anabolic and saw only limited use in a small number of markets. Eventually all manufacturers of this product ceased production of the injectable and oral forms of the compound. Although the injectable version of this product are now off the markets, clostebol acetate is still manufactured by a number of companies in the form of a dermal preparation. The most popular brand of this product is produced in Italy. The dermal preparations of this steroid are usually used in the treatment of wounds and ulcers.
Clostebol acetate is a fairly weak anabolic compound offering little in terms of muscle building ability. Results seen by users of this drug would be similar to those seen by taking oral forms of primobolan, though probably not as strong and pronounced. Clostebol acetate does not convert to estrogen and there for estrogenic side effects such as water retention bloat and gyno aren’t a factor and the user need not worry about taking anti-estrogen compounds such as arimidex or aromasin. Clostebol acetate does have some stronger androgenic properties; therefore androgenic side effects are possible when using this steroid at higher doses. Androgenic side effects may include things such as oily skin, acne, and increased growth of facial and body hair. Because it has no estrogenic activity but is moderately androgenic, users of this compound can expect the muscle gained to have a quality lean look to it. Because of this, Clostebol acetate would be used by bodybuilders nearing a show, or by athletes in speed or weight regulated sports. Users of this product may choose to stack it with other non aromatizing steroids such as winstrol, anavar, or an injectable such as trenbolone or deca durabolin. Like other anabolic steroids, use of Clostebol acetate can suppress the body’s natural testosterone function, thus making a post cycle therapy protocol necessary at the end of the cycle. Most users choose to use products such as clomid and HCG after they discontinue anabolic steroids in order to restore natural testosterone function.
Men would typically use Clostebol acetate in dosages of 200-500mg a weekfor a period of 8-12 weeks. Due to the fast acting nature of the acetate ester, Clostebol would need to be injected every day or every other day in order to keep blood levels as stable as possible. Women often choose a dosage of around 50mg a week taken for 4-6 weeks to see desirable effects while keeping masculizing side effects such as deeping of the voice, or the growth of facial hair, to a minimum.
