HOW TO BULK UP
First things first:
There are many reasons that bulking diets fail but here are a few of the most common reasons:
1) Calories are not high enough and putting on muscle mass fails2) Calories are too high and macros percentages are not in check. This in turn leads to putting on sloppy weight (fat) as well as muscle.
3) You are BULKING, not CHEATING. Cheat days will be factored in, but your food choices should still be healthy. All diets, whether cutting or buking, need to be monitored. This means that watching your insulin spikes and TYPE of carb intake is still important.
4) You are what you eat. It’s just that simple. To simplify, you eat crap and you will look like crap.
That being said let’s talk calories and figuring out daily needs
Harris Benedict Formula for Calorie Calculations
“The Harris Benedict equation is a calorie formula using the variables of height, weight, age, and gender to calculate basal metabolic rate (BMR). This is more accurate than calculating calorie needs based on total body weight alone. The only factor it omits is lean body mass and thus the ratio of muscle-to-fat a body has. Remember, leaner bodies need more calories than less leaner ones. Therefore, this equation will be very accurate in all but the very muscular (Harris-Benedict will under-estimate calorie needs) and the very fat (Harris-Benedict will over-estimate calorie needs).”
That being said, there are is no concrete number of daily calorie intake your body needs, however using this formula will give you can idea of what you do need.
Harris Benedict Formula for Men
BMR = 66 + (13.7 X weight in kilos) + (5 X height in cm) - (6.8 X age in years)Notes:
1 inch = 2.54 cm.
1 kilogram = 2.2 lbs.Example of BMR
You are 25 years old
You are 6 feet tall
Your weight is 220 pounds
Your BMR is 66 + (1370) + (914) - (170) = 2180 caloriesHarris Benedict Formula for Men - STEP 2
To determine your total daily calorie needs, now multiply your BMR by the appropriate activity factor, as follows:If you are Sedentary - little or no exercise
Calorie-Calculation = BMR X 1.2
- If you are Lightly Active (light exercise/sports 1-3 days/week)
Calorie-Calculation = BMR X 1.375
- If you are Moderately Active (moderate exercise/sports 3-5 days/week)
Calorie-Calculation = BMR X 1.55
- If you are Very Active = BMR X 1.725 (hard exercise/sports 6-7 days/week)
Calorie-Calculation = BMR X 1.725
- If you are Extra Active (very hard daily exercise/sports & physical job or 2X day training)
Calorie-Calculation = BMR X 1.9Total Calorie Needs Example
If you are lightly active, multiply your BMR (2180) by 1.375 = 2997
Your total daily calorie requirement is therefore 2997 calories.
This is the total number of calories you need in order to MAINTAIN your current weight.If you want to gain body weight, you must consume more calories than you burn. One pound of body weight is roughly equivalent to 3500 calories, so eating an extra 500 calories per day will cause you to gain one pound a week. Etc….
