Equipoise (Boldenone Undeclynate)
Boldenone Undeclynate is the chemical name of the steroid we know as Equipoise. In order to make a steroid for use in the veterinary industry, the structure of the Dianabol product changed. Since it is more efficient to inject an animal every few weeks instead of feeding it steroids daily, the hormone was modified to create a product for intramuscular injection. By adding an ester (Undeclynate) to the hormone, scientist created a product that could suspend into an oil solution while also slowing down the rate at which the hormone will be used by the body. A single injection of Equipose can slowly release and be used by the muscles for as long as six weeks after administration.
The common believe in the steroid world is that Equipoise will take up to four weeks to build up in the body before the user sees noticeable effects. It is also believed that Equipoise will taper off slowly at the end of a steroid cycle, so using Equipoise at the end will help make Post Cycle Therapy more effective.
How to use Equipoise?
Doses of 400mg per week are normal when this steroid is used by itself. As part of a steroid cycle Equipoise can be used at a lower dose of 200mg per week, as long as the other steroid in the stack are dosed aggressively. For experienced steroid users the benefits are negligible at less than 200mg per week. Equipoise has not earned an exclusive classification as neither a bulking or cutting steroid. Instead, it is being widely use for both purposes with great results.
Equipoise side effects?
Acne and anxiety is the most common negative experience from those who use Equipoise. It does not have any noticeable estrogen-like effects so breast tissue growth is not a common occurrence.
Where to buy Equipoise?
This product is widely available from many sources and it is fairly inexpensive as well as easy to find as long as the risks are understood. Buyers must be weary of any seller that claims to sell human grade Equipoise as such a product does not exist. Equipoise is one steroid that was manufactured with the exclusive intent of animal use, although humans may use it with good results.
How is Equipoise packaged?
Since Equipoise was meant for farm animals that are physiologically more responsive to steroids than humans, Equipoise would be dosed at 25mg to 50mg per milliliter in its veterinary presentation. Once the manufacturers of veterinary steroids in Mexico realized that much of their Equipoise was being used by American bodybuilders, they quickly adapted and changed their product to meet the needs of their real customers. Equipoise began to come in at 100mg and even 200mg per milliliter strengths. The higher potency with lower volume was welcomed by bodybuilders who were happy to inject less oil while still meeting their required dosages. In recent years the underground market has seen Equipoise in concentrations as strong as 400mg per milliliter, although the common dosage is usually 200mg per ml.
