carbohydrate cycling
Carb Cycling.
This approach allows the athlete to either gain maximum muscle mass without gaining too much fat (sometimes a slight fat loss is even possible) or to get into contest shape while maintaining (or even gaining) muscle mass. The strategy is actually not complicated and it's the most effective way to diet
The Logic Behind the System
There are two inevitable truths when it comes to building muscle or losing fat:
1) To increase body mass you need to consume more calories than you use.
2) To lose body fat you need to consume fewer calories than you use.
Obviously, the type of food you ingest will have an important impact on the end result. If the bulk of your calories come from junk food, chances are you'll end up gaining more fat than muscle. Similarly, if the quality of your food intake is low while dieting, chances are you'll end up losing more muscle tissue.
So, it's true that whatyou eat is just as important as how much you eat. However, total food intake still remains of paramount importance when trying to either gain muscle or lose fat.
Another thing to consider is the effect of nutrients on hormones and the effect of hormones on muscle gain and fat loss. For example, insulin is one of the most important anabolic hormones in the body. It directly influences the amount of amino acids and glucose transported into the muscle cells. This is the good stuff, and the more of it you have, the more you grow.
Basically, insulin is responsible for transporting the bricks to the construction site. Insulin also prevents the mobilization of the nutrients stored in the muscle either as intramuscular glycogen or muscle tissue. So in that regard, insulin favors muscle gain and diminishes muscle wasting. This is why insulin is widely used by professional bodybuilders.
However, since using exogenous insulin is out of the question for any natural individual remotely interested in avoiding diabetes and premature death, we must stimulate our body to produce its own insulin. Insulin is released from the pancreas in response to an increase in blood glucose level (which occurs when consuming carbs and certain amino acids). So if we want to increase endogenous insulin production, it becomes necessary to consume a mix of carbs and amino acids.
On the other hand, glucagon, which is insulin's antagonistic hormone, promotes the mobilization and utilization of stored nutrients, including glycogen and amino acids. When your diet is low in carbs, your glucagon levels skyrocket, putting you into mobilization/breakdown mode instead of building/anabolic mode.
We also have to mention that without ingesting carbs, it's harder to have intense strength training sessions. It's true that some amino acids can be "turned into" glucose via gluconeogenesis, and that ketone bodies can be used for fuel after proper adaptation has set in. But truth be told, a low/no carb diet makes you lose your capacity to train hard in the gym.
You also risk losing muscle mass because your body might very well decide to break up muscle tissue into amino acids to create new glucose! You could literally burn down the walls to heat the house!
Lastly, the conversion of T4/thyroxine (the relatively inactive thyroid hormone) to T3/triiodothyronine (the active thyroid hormone) is greatly impaired when insufficient carbs are consumed. A lower level of T3 leads to a drop in metabolism and this makes losing fat much harder.
For these reasons we can see that consuming carbohydrates is necessary if we want to develop a muscular body. However, insulin also has an ugly side: it can promote fat storage as well as reduce fat mobilization and usage.
A chronically elevated insulin level has a profound effect on the body's capacity to increase body fat. On a related subject, excess carbs can also be stored in fat cells. So always consuming large amounts of carbohydrates can lead to a physique reminiscent of the Michelin Man!
So What Can We Do?
To stimulate maximum muscle growth you need carbs, and a relatively high amount to boot. Without ample calories and carbohydrates, it'll be hard to gain heaps of muscle tissue, even with a high protein intake. However, eating too much too often can also make you fat. Head-splitting, isn't it?
The first method used by bodybuilders was to divide their training year into bulking and cutting phases: consuming tons of calories and carbohydrates during their bulking phase, then dropping their calories and carbs to sub-maintenance levels when entering a cutting phase. This worked...somewhat.
It did allow many people to gain a lot of size, but most of them lost quite a bit of their new muscle during the intense dieting period. Not to mention that those who were cursed with bad insulin sensitivity tended to gain a lot more fat than muscle during "bulking season." Also, gaining and then losing 20-30 pounds isn't exactly healthy. It puts a lot of stress on the body and can lead to some health problems.
Finally, from an aesthetic perspective, ballooning up by gaining 15-20 pounds of fat for the sake of gaining 10 pounds of muscle isn't the best thing to do. Ideally, we want to look good naked most of the time, not on a few selected months out of the year. "Sorry babe, not with the lights on this month. I'm bulking."
Then the cyclical ketogenic diets began to appear. These were based on a relatively long period of carb deprivation (normally five straight days) where less than 50 grams of carbohydrates were allowed, followed by one or two days of carbohydrate loading.
While very effective at stimulating fat loss, the long period without carbs isn't conducive to maximum muscle accumulation. In fact, by the second or third day you're pretty much in a severe catabolic state. Sure, there's an anabolic rebound during the loading days. But I'm not sure if this can be enough to compensate for the rest of the week. I do believe that it's enough to prevent muscle loss on a weekly basis, but not enough to promote maximum muscle gain.
To be fair, I've used this type of dieting several times in my life and did get great results as far as fat loss is concerned. I was even able to add a small amount of muscle, but I was never able to gain a lot of it on this type of diet.
Finally, a third approach championed by guys like Dr. John Berardi started to gain popularity. This dietary approach was based on not consuming many carbs and fats togetherand on consuming carbs mainly during periods of increased insulin sensitivity (in the morning and post-workout). So you basically had three meals with carbs and three meals without them every day.
This approach is darn near perfect for gaining mass with minimal fat accumulation. However, I found that it could still be improved to get the best body composition results.
The Solution
The solution that I'll (finally) explain to you is called carb cycling, but it could also be called calorie cycling. It sticks to the basic theory of ingesting carbs only in the morning and after workouts. The only difference is that the amount of calories and carbs consumed will vary each day. What will this accomplish?
• It'll allow you to include maximum fat burning days and maximum muscle accumulation days in each week.
• It'll prevent metabolic slowdown by providing frequent caloric spikes.
• It'll favor long term success because it's relatively easy to follow, especially compared to the more restrictive ketogenic diets.
Carb Cycling: The Basic Structure
Carb cycling is based on having three different carbohydrate intake levels during the week: high(er) carbs, moderate carbs, and low(er) carbs. Ideally these days are split according to your training schedule.
If you train 4 times per week:
• Select your two "priority workouts." These are the workouts where you're training the muscle groups you need to improve the most. On these days, you have a high(er) carbohydrate day.
• On the two other workout days, you consume a moderate amount of carbs.
• On the three "off days" you have a low(er) carb intake.
If you train 3 times per week:
• Select your two "priority workouts." On these days, you have a high(er) carbohydrate day.
• The other workout day has a moderate carbohydrate intake level.
• Among the four remaining days of the week, you have one more moderate carb day along with three low carb days.
If you train 5 times per week:
• Select your two "priority workouts" where you're training the muscle groups you want to improve the most. On these days, you have a higher(er) carbohydrate day.
• Select two "secondary workouts." On these days you have a moderate carb intake.
• On the remaining workout day and during your "off" days you consume a low(er) amount of carbohydrates.
Basically, one sentence could summarize the carb cycling philosophy: "Eat for what you did and have to do."
Calories and Carbohydrate Levels
When you've established your basic structure, you need to set the food intake appropriately. The first thing to do is calculate your daily energy expenditure: the amount of energy (in calories) you use each day. This baseline figure will be used to set caloric and nutrient intake during the various types of days.
First Step: Calculating Your Basal Metabolic Rate
Your basal metabolic rate (BMR) simply means the amount of energy used by your body during a 24-hour period if no activity is performed. In other words, if you're inactive for 24-hours straight, you'd still "burn" the amount of calories equivalent to your BMR.
Your BMR is a function of your size, sex, and age. It's also influenced by your metabolic status (hypo or hyperthyroid state for example). We can calculate BMR with the following formulas (by Harris-Benedict):
For Men
BMR = 66 + (13.7 x weight in kg) + (5 x height in cm) - (6.8 x age)
So for a 30 year old bodybuilder of 220lbs (100kg) at 5'11" (178cm) it comes up to:
BMR = 66 + (13.7 x 100kg) + (5 x 178cm) – (6.8 x 30)
BMR = 2122 calories per day
For Women
BMR = 655 + (9.6 x weight in kg) + (1.7 x height in cm) - (4.7 x age)
So for a 28 year old figure girl of 132lbs (60kg) at 5'6" (165cm) it comes up to:
BMR = 655 + (9.6 x 60kg) + (1.7 x 165cm) – (4.7 x 28)
BMR = 1380 calories per day
Second Step: Factoring in activity level
The amount of calories found using the Harris-Benedict formula is what your body burns every day, even if you do nothing all day. Obviously, the more active you are the more you'll burn fuel. So, energy expenditure will be increased when your activity level goes up.
To get an adequate estimation you need to multiply your BMR by an activity level factor:
By sedentary we mean doing nothing all day (sleeping and watching TV).
By very light activity we mean doing nothing physical. Working a desk job or on a computer and not performing any type of physical activity during your day.
By light activity we mean having a non-physical job (desk, computer, etc.) but performing some sort of physical activity during the day (e.g. above average walking) but no hard training.
By moderate activity we mean having a non-physical job, performing some sort of physical activity during the day, and including a daily workout session in your routine. This is where most of you are at.
By high activity we mean either training plus a physical job or non-physical job and twice-a-day training sessions.
By extreme activity we mean a very physical job and daily hard training.
So if our 220 pound bodybuilder with a BMR of 2122 calories/day is moderately active, his daily energy expenditure is bumped up to 2122 x 1.6 = 3395 calories per day. This is the amount of food to consume to maintain present body weight.
Third Step: Adjusting caloric intake to your goal
To gain muscle you should ingest more calories than you use up each day. To lose body fat you must do the opposite. A 20% increase or decrease seems to be ideal for most individuals. This isn't a drastic increase/decrease, so it shouldn't lead to excessive muscle loss or unwanted fat gain.
Our sample bodybuilder has a daily caloric expenditure of 3395kcals/day. If he wants to gain muscle mass he should bump his caloric intake up to 4074kcals/day. And if he wanted to lose fat he should decrease it to around 2716kcals/day on average.
Note that depending on your body type and metabolism, you may need to adjust these figures. Ectomorphs will need to increase caloric intake more than 20% to gain muscle maximally (around 30% is best for them) and they should decrease it less when trying to lose fat (by 10% instead of 20%). Endomorphs should only increase by 10% when trying to gain size, but lowering it by 20% is adequate for them when trying to lose fat.
For example, if our 220 pound bodybuilder is an endomorph he should ingest 3734kcals/day when trying to gain mass (instead of 4074kcals/day).
Fourth Step: Setting nutrient intake for the "moderate days"
Protein intake should remain stable during all three types of day. At least one gram per pound of bodyweight is necessary, but I recommend 1.5g/pound of bodyweight for better results (so 330g/day for a 220 pound individual).
When trying to gain mass, the carbohydrate level on the "moderate" days should be the equivalent to the protein intake. So in the case of our 220 pound bodybuilder, that comes up to 330 grams.
So he's now consuming 2640kcals/day (1320 from proteins and 1320 from carbs). Let's say that he's an endomorph. If he wants to gain muscle mass, his caloric intake should be around 3734kcals/day. So he has 1094kcals to consume in the form of fat, preferably good fats. Since fat has 9kcals/g, this comes up to 121g of fat per day.
So to recap, our endomorph bodybuilder of 220 pounds wanting to gain size should consume the following on "moderate" days:
330g of protein
330g of carbs
121g of fat
If he desires to lose fat, carb intake on the average days should be set at 1.25g per pound of bodyweight. For our sample guy that comes up to 275g per day.
Protein intake is kept at 1.5g/pound of bodyweight (330g in our example) and the rest of the calories are made up with fat.
In the case of our endomorphic bodybuilder who should consume 2716kcals/day to get ripped, we come up with 2420kcals from proteins and carbs, so he has around 300kcals to consume in the form of fat, or 33g/day.
To recap, our endomorph bodybuilder of 220 pounds wanting to get ripped should consume the following on "moderate" days:
330g of protein
275g of carbs
33g of fat
Fifth Step: Setting nutrient intake for the other days
Protein and fat intake remains constant during the week. Only carbs fluctuate up and down. During high(er) carb days, bump carbohydrates to 125% of moderate days. During low(er) carb days, intake is lowered to 75% of the moderate days.
To continue on with our example, our 220 pound bodybuilder would consume:
1) When trying to gain mass:
High(er) carb days = 330g protein, 412g carbs, 121g fat
Moderate days = 330g protein, 330g carbs, 121g fat
Low(er) carb days = 33g protein, 247g carbs, 121g fat
2) When trying to lose fat:
High(er) carb days = 330g protein, 344g carbs, 33g fat
Moderate days = 330g protein, 275g carbs, 33g fat
Low(er) carb days = 330g protein, 206g carbs, 33g fat
Sixth Step: Adjusting intake as the diet goes along
Warning: In my honest opinion, no one who's trying to get muscular should follow a restrictive fat loss diet for more than 16 weeks in a row. And most people would be better off using 8-12 weeks of dieting.
More than that and you're bound to lose muscle mass or at least limit your capacity to gain muscle mass. If you haven't gotten to the degree of leanness you wanted after 12 weeks of dieting, take 4 weeks "off" of your diet (continue to eat a good clean diet, but increase your calories) and then go for another dieting period.
When trying to lose fat, you'll need to eventually lower your calories as your body gets used to your level of food intake. With carb cycling this is less of a problem since carbohydrates and calories fluctuate. But still, every 3-4 weeks you'll need to decrease carbohydrates and calories slightly to continue losing fat at an optimal rate.
However, you shouldn't make any drastic cuts, as this is the reason most people lose muscle during a fat loss diet. I suggest dropping around 20g of carbs per day every 3 or 4 weeks. For example, if you're consuming 344g, 275g, and 206g, you'd reduce it to 324g, 255g, and 186g. If fat loss hasn't slowed down, there's no need to reduce anything though.
When trying to gain mass, there's no set pattern of increasing caloric intake. If after 2-3 weeks you haven't been gaining size, increase protein and carb intake by 25g each. At first, add this amount to your post-workout meal. If after another 2-3 weeks there's no change, add the same amount to your breakfast. If you're still not gaining, add some more to your post-workout shake, etc.
Carb cycling: Yeah, it seems to work!
Meal Breakdown
To maximize food absorption and favor muscle gain over fat gain (or to preserve muscle mass while dieting) you should ingest 6-7 meals per day. Three of those meals should contain carbs and proteins (breakfast, immediate post-workout drink, and meal 60-90 minutes after your workout). The remaining 3-4 meals should be made up of protein, good fats, and green veggies.
The ideal time to train is around 10:00am. This gives us the following eating schedule:
Meal 1 (upon waking up): Carbs + protein meal
Meal 2 (post-workout, around 11:00): Carbs + protein recovery drink (Surge)
Meal 3 (12:30): Carbs + protein meal
Meal 4 (15:30): Protein, fat, and green veggies
Meal 5 (18:00): Protein, fat, and green veggies
Meal 6 (21:00): Protein, fat, and green veggies
Obviously, not everybody can train at this time. For those who have to train in the evening (around 5:00 or 6:00pm), the following schedule is appropriate:
Meal 2 (10:00) Carbs, protein, and green veggies
Meal 3 (12:30): Protein, fat, and green veggies
Meal 5 (Post-workout, around 18:00): Protein and carb drink
Meal 6 (21:00): Carbs + protein meal
Finally, those who have to train in the morning (around 8:00am) should use the following schedule:
Meal 1 (upon waking up): Carbs + protein meal drink
Meal 2 (post-workout, around 9:00): Carbs + protein recovery drink (Surge)
* Note that in this last situation we use a carb and protein drink in the morning. This is because we need to get the nutrients absorbed as fast as possible so that digestion won't interfere with workout intensity.
Nutrients Per Meal
Since protein is ingested at all meals, it should be evenly divided. For example, if you consume 330g of protein per day, you should aim for 6 meals of 55g each.
Fat is ingested in 3 of the 6 meals and it should be equally divided among them. So if you have to consume 100g of fat, this comes up to 33g of fat in each of the 3 meals.
Carbohydrates are also ingested in 3 meals. About 50% of your carb intake should be consumed immediately post-workout, 25% in the morning and 25% around 60-90 minutes post-workout. So if you have to ingest 250g of carbohydrates per day, it comes up to 125g post-workout, 75g in the morning, and 75g about 60-90 minutes post-workout.
Food Choices
We've been talking about quantities for a while, but it's time now to talk about quality! A calorie is not a calorie; not all foods are created equal. To maximize your results, you thus need to put the right stuff into your body. Here's a quick list of the appropriate foods for each type of meal.
Breakfast (carbs + protein)
Protein sources: egg whites, Low-Carb Grow!, tuna, chicken
Carb sources: fruit (1-2 pieces to fill liver glycogen), oatmeal, grits, sweet potatoes, All-Bran cereal, buckwheat pancakes (no syrup)
Post-workout (carbs + protein)
Rice to fill the remaining carb requirement
60-90 minutes post-workout (carbs + protein)
Protein sources: chicken, fish, shrimp, lean cuts of meat, Low-Carb Grow!
Carb sources: sweet potatoes, brown rice, tomatoes, carrots, mushrooms, grits
Protein + fat meals
Protein sources: all cuts of meat, fish, chicken, turkey, tuna, Low-Carb Grow!, eggs, ham, cottage cheese
Fat sources: protein foods above, fish oil, flax seeds
Green veggies: 100-200g
Conclusion
If this article was somewhat more complex than my regular work, I apologize. However, to make the most out of your diet you can't simply "wing it." Paying attention to details is important and is sure to pay off in the near future.
This type of dieting has been proven effective in most individuals. In the long run, it'll lead to a much more muscular and leaner physique. It takes work, but your efforts will be rewarded!
