Best Bulking Anabolic Steroids
Bulking is an art. An art that takes a ton of effort to be successful at. Especially when you are a seasoned juicer who has already put on some mass. If you have not gained at least 20 pounds over the weight you were at before coming over to the dark side, you just have not been juicing effectively and you will be very happy with the information that follows. If you have put on a good deal of size, you will still find useful information in the following paragraphs, but for now, we will not discuss usage of other non-anbolic steroid bulking drugs such as insulin. We will get to that soon though. Keep reading!
The catch with bulking drugs is that you have to accept not being so pretty if you are to really put on some size. Water and a little fat weight have to come with adding considerable size unless you are a genetic abnormality. The most potent drugs for bulking involve the heavy androgenic drugs which also cause large amounts of water retention. All the testosterone esters, anadrol, dianabol, and deca or equipoise when combined with any of the former make for a good bulking team.
One thing you want to take into consideration with here is the mechanism by which each drugs works. Anabolic steroids are either known to have a high affinity for the androgen receptor, and thereby cause growth through this mechanism, or they have effects on growth outside the receptor. For max benefit you want to combine drugs that work by different mechanisms. All orals will work by different mechanism purely on the fact that they are ingested and not injected. The way you get a drug into your body is called the route of administration.
When an oral drug is taken it must eventually pass its way through the liver. The first time it does this a few hours after you ingest the oral is the popular term, "first pass". This is just code for the first time the liver has a chance to break down the oral drug. This site of metabolism is also where the functionality of oral anabolic steroids come into play.
The 17 alkylation of oral anabolics is what makes the drug able to pass the liver and not be fully degraded. Otherwise you would be able to drink testosterone and it would work fine. We all know this is not the case. The hydrochloric acid in the stomach would destroy the testosterone molecule way before the liver even gets a chance to metabilize it. This is why the oral test "methyltestosterone" came into existence. Although it is not a very effective drug, it is highly toxic. Methyltestosterone is a prototype oral. It has the most basic of structures added to testosterone to enable its hepatic(liver) survival. They simply added a CH3 or "methyl" group to the 17th postiion on th molecule (you've most likely seen it, it is the thatched roof part of the steroid structure). The reason why I mention this is that the toxicity of orals due to their chemical make-up is not all bad. When a 17 orally alkylated drug passes by the liver, it forces the liver to kick out a little extra IGF-I each time. IGF-I is the most potent anabolic substance in the body. It is through IGF-I modulation that the use of growth hormone exerts its muscle building effects. The moral of the story:
USING AN ORAL DRUG WILL GREATLY IMPROVE THE RESULTS OF YOUR BULKING CYCLE.
Regular old testosterone is one of the best bulking drugs there is. As long as you are not super sensitive to estrogenic side effects, this should be your staple for mass building. Novices usually use around 500mg a week of a long acting ester. More advanced bodybuilders use upwards of 1000mg a week. The best way to do this is to find yourself some cheap multi-dose vials of a long acting test like enanthate. But I'm not "telling you to do this", ummm...this is for information purposes only...ok...hypothetically...If you use a shorter acting ester like propionate, it will be much more painful to administer and you will definitley not administer this amount. Prop at 100mg eod is more the norm for novices, 100-200mg daily for advanced. Prop usually comes 100mg/cc, two cc's in one shot of prop hurts!! You will definitely experience some welting if you try this. I do not recommend it. You will either be limping or rubbing your shoulder almost daily. This is miserable. Long acting esters like sustanon, enanthate, cypionate, etc. do not cause this extrem discomfort. Please keep this in mind.
Okay, so we have an oral, either dianabol or anadrol, with an injectible testosterone, and now you need a even blood level anabolic like deca or equipoise. Either one will suffice. Remember though, as we've said before, combining aromatizing drugs such as anadrol testosterone esters with progestagenic drugs such as anadrol is very risky for all but those who are not susceptible to gyno. So be careful. Even if you have used androgenic drugs such as test before with no chest soreness, be careful. If you decide to do this, you will want at least one estrogen on hand for precautionary reasons.
Assuming all is well, and you choose to take this aggressive technique, you will need at least a 2mg/lb of bodyweight per week of the injectible anabolic. You could technically use primo or winstrol as well for a little less overall bloat. The dosage patterns will be different with these drugs if used for this purpose and we will talk about this in the future. For now lets assume either deca or eq. Deca at 300-400mg/week is often used by novices, 600-800mg for advanced. In all the athletes I have known, I have not seen a reason to go above 500mg when combining deca or eq with both an oral and a testosterone ester. This dose should be more than enough to get you gaining and keep your joints from aching while you push all that heavy iron (we will get into joint/ligament/tendon properties of anabolics soon).
