Anabolicum Vister (Quinbolone)
Anabolicum Vister is an oral version of the popular hormone boldenone which has a delivery method similar to andriol and was created in an effort to be a completely safe oral in the same manner that andriol is considered. It uses a similar delivery system to get into the blood as andriol, except with the focus being a shorter ester which was done by adding an ether attachment to the C17-a position to increase the speed at which the hormone was absorbed by the body. The final preparation is provided in an oil sealed capsule with the idea being for the drug to be absorbed by the lymphatic system and avoid being processed by the liver. The problem is that this mechanism doesn’t really worked as planned, and those using the drug are often just feeding large doses of boldenone to the liver. While this is harmless, it does hinder seeing the desired effects of the hormone because most of it never makes it into the blood, thus requiring very high dosages of quinbolone to be consumed in order to see any real effects.
The results from anabolicum vister will be similar to those seen from equipoise, since the drug is essentially nothing more than boldenone with ether attached to it and the structure of the hormone and its metabolites haven’t been changed in any way. The steroid is very mild androgenically due to the fact that it has virtually no interaction with the 5AR enzyme therefore not forming a more androgenic metabolite. As far as estrogen is concerned, it is only about 50% as estrogenic as testosterone so there are no real worries of estrogen related side effects when taking this drug. Due to the fact that it’s a non 17-alpha-alkylated oral, the drug is and out of the system very quickly with no long term recovery worries becoming an issue. This would also benefit the drug tested athlete as he would be able to get the hormone out of the system very quickly after discontinuing use. Quinbolone is very mild on the system and toxicity is not an issue when using this compound. Because of this, it can be stacked with virtually any other compound and used for extended periods of time.
Dosage of anabolicum vister varies depending on the user’s goals. Typically, a dosage of 20-25 caps a day would be the equivalent of 300-400mgs a week of equipoise, so knowing this, users should adjust their dosage accordingly. Unlike most other orals, quinbolone is unable to show effects beyond its short half life, therefore, it is essential the dosages be split up over the course of 3-4 times a day. This hormone is safe for use by women due to its mild nature and low androgenic properties. Women should find a dose of 10-15 capsules a day sufficient.
Currently, anabolicum vister is considered to be an extinct steroid with the last known manufacturer being Parke Davis. It appears as if though the steroid was far too mild and pricy at the dosage required to ever gain much popularity and thus production was eventually ceased.
