Originally posted by Gymrat827
View Post
kicking around ideas with tren...
hey you could try it. less tren equals less sides. at a certain point, it'll also equal less gains though. i'd have to wonder, would a low low dose of tren be as beneficial as a standard dose of another compound? when i run it, i'm going to start with just 50mg EOD. if i'm ok, i'll bump it up to 50mg ED. i dont plan to go higher than that.if you are new to the board, please take a minute to read the rules...CLICK HERE
Originally posted by bugse2342 View PostThat is goin to be my plan. I am just goiing to run a low dose cycle to see how my body reacts to it. If it works out, i will stack it with some test cyp or maybe sus270 for the next cycle.if you are new to the board, please take a minute to read the rules...CLICK HERE
Originally posted by sam1976 View Posthey you could try it. less tren equals less sides. at a certain point, it'll also equal less gains though. i'd have to wonder, would a low low dose of tren be as beneficial as a standard dose of another compound? when i run it, i'm going to start with just 50mg EOD. if i'm ok, i'll bump it up to 50mg ED. i dont plan to go higher than that.
I also think the oral would clear alot faster than ace if i was getting lots of ill effects......can anyone confirm this??
Originally posted by Gymrat827 View Postif i did 75mg EOD it would be 262mg a wk....i think that would be a good dose to assess if i can use this stuff or not..??..?? but now i am also interested in GP oral tren. i know its toxic as all hell but 750mcg or 1mg shoudnt be too bad.
I also think the oral would clear alot faster than ace if i was getting lots of ill effects......can anyone confirm this??Last edited by sam1976; 01-13-2012, 12:07 AM.if you are new to the board, please take a minute to read the rules...CLICK HERE
Originally posted by bugse2342 View PostIwas going run it with andro gel and add some proviron into cycle, but if you suggest test cup (which I have available) I will run that. I was trying to save it for another cycle
Originally posted by sam1976 View Postlololololol. nooooooo! dont do it bro. oral tren is a whole different animal. side effects are the harshest of all tren. it's like, ummmm...its like tren on steroids lol. and 750mcg to 1mg would be a huge dose for a first timer. hell, thats a pretty big dose for anymore. you can only use OT for around 3 wks at a time. i made it 2 wks, worked up to 750mcg and called it quits when i started getting overly sensitive to heat. i sometimes work in a hot enviorment and i started to stroke out when it heated up. trust me. oral tren is a very advanced drug. and honestly, you'll do better in the long run on ace. you can run it longer to reap more benefits. 75mg to 100mg of tren ace EOD is a pretty standard dose. if you're gonna try it, just go for it. that dose would work well.
i have looked into it before...dosing really. and than did a bit today. all the stuff i read was guys taking 1.5-2.5mg ED!!!???
some of it was here to (JM)...?? a bit on ology and other random places. so i figured 750mcg wouldnt be too bad
Originally posted by bugse2342 View PostIwas going run it with andro gel and add some proviron into cycle, but if you suggest test cup (which I have available) I will run that. I was trying to save it for another cycleif you are new to the board, please take a minute to read the rules...CLICK HERE
Originally posted by Gymrat827 View Posti have looked into it before...dosing really. and than did a bit today. all the stuff i read was guys taking 1.5-2.5mg ED!!!???
some of it was here to (JM)...?? a bit on ology and other random places. so i figured 750mcg wouldnt be too badif you are new to the board, please take a minute to read the rules...CLICK HERE
500mcg is where id plan on starting. but now i am thinking i may as well just get anavar or mast. var is my 1st choiceLast edited by sam1976; 01-14-2012, 12:35 AM.
