I was curious because I've read that it's possible to use 27G pins when administering Test En. I ask because I will be starting my first pin cycle and am a little confused as to the gauge for pinning and the gauge for drawing, also can the drawing pins and barrels be used more then once ??? Any information or prior experiences are all welcome
pins/test
never use anything more than once, the stuff is cheap and only using it once can save you from an expensive and painful infection. i draw with a 20x1.5 and pin with 25x1s. you could prob pin with a 27 but the oil is pretty thick and youll have to hold the needle in the muscle for a long time so that thick oil can make it thru the thin little pin. 25g is the most common size for pinningPain is just weakness leaving the body
Originally posted by PushinWeight View Posti used to use 22 gauge and i had to push them in so hard, they would dimple the skin before they pierced it. 25s work much better for me
1tuff, there are tons of places to get pins online. U don't have to wait u can order today and get em 3 days later.
Originally posted by 1tuffcookie View PostHey weight that's what the general majority conclude, 25 to pin 22 to draw. Now if our sponsor would open back up I could get started......
Sam's the man! When 1st questioned about pinning I read this. Also has a great site to order from right in FLA which works out to be next day shipping for me.
Originally posted by sam1976 View Post
Originally posted by nyc View PostI like 23g 25g
Cannot feel a difference between the two - 23g takes 2sconds 25g takes 20seconds
but I once used a slin pin (in a pinch) 1cc in the delt (it worked well warmed up the oil.)
necessity is the mother of invention"GYM + JUICE"
