Originally posted by pureflint
View Post
What's your next cycle going to be?
I just got my test e 200/ test eq 200 I got 4 vials so either 400mg for 20wks or 600mg for 15wks. Also got tbol to kick start 30mg for 6 weeks and some winny to tail the cycle with (left over and I want to use before it goes bad) at 20mg for 4 wks. Im exicted for this. im going to be cutting with natural then eventually bump in some t3 and clen. once im done with that ill be jumping on this cycle. Looking forward to meeting some goals I have planned for jan 31 2014. Its a long ways out but i need the time!
I'd go with the 600 at 15 weeks. I like the cycle.Originally posted by Ares View PostI just got my test e 200/ test eq 200 I got 4 vials so either 400mg for 20wks or 600mg for 15wks. Also got tbol to kick start 30mg for 6 weeks and some winny to tail the cycle with (left over and I want to use before it goes bad) at 20mg for 4 wks. Im exicted for this. im going to be cutting with natural then eventually bump in some t3 and clen. once im done with that ill be jumping on this cycle. Looking forward to meeting some goals I have planned for jan 31 2014. Its a long ways out but i need the time!
12 weeks for the mixOriginally posted by ANABOLIC DOGG View PostHey, Liquid how long are you going to run that mix? And as far as the gh that sounds real good never used it how long have you got to run it ?
You can run the GH for as long as you'd like. You will hear people say 6 months minimum to see results but that's not true. If you do it right in conjunction with Test, etc. you will see a change a lot faster than 6 months. That is of good quality GH like the HYGETROPIN from Naps.
