Hello. how QDL testosterone propionate and trenbolone acetate works? or is GP prop and tren better? i dont havent used both of these first time injections some1 answer please!
QDL / GP experience
okay im going to test QDL or GP thanks for answers . yes this is my first injectable cycle silverblack. But im wondering to get much of muscle and getting shredded at the same time..? can i take only propionate to gain muscle? and how many kilos i can get 10-12week propionate 500mg week? or it is big difference if i add tren A. 300mg week 8-10weeks? how many kilos i can add muscle with tren and prop? and ethanWS6 have you tried Qdl's testosterone propionate that one which costs 22$ ?
honestly, if it's your first cycle, you need to stick with enanthate or cypionate esters. Prop is a pain in the ass because of how often you have to shot it especially if you aren't used to injecting in the first place. Also, you don't want to add tren of all things for your first run. Tren is one of the most powerful anabolic steroids on the market. You need to take it slow when first starting out. 500mg/wk of test enanthate for 12 weeks will give you some great gains!
Sustanon 250 from either Biomex, Gen Shi, or QDL, or Sustanon 270 from GP would be my recommendation for you. I would start with 1 ml every 5 days and go from there... You will achieve greater results than you have ever imagined if you have an exceptional diet and exercise regime.Somebody out there is working harder. Somebody wants it more.
Listen 2 these guys deltbrah. I've. Recently joined jm but I've been coming 2 this forum for well over a year and these guys know wat they're talking about. I perfer sustanon as my 1st choice for bulking then test cyp. Stay away from tren until u got at leas 4-5 cycles under ur belt. I've ran 5 cycles already and I've still not touched the tren. Imy best bulking cycle is 500+ sust 400+ deca and 30mg dbol. I've always managed 2 pack on 20-25lbs of weight each time I've ran this cycle(obviously not all was muscle). Most say that ur 1st cycle should be just a test cycle, which is ok by itself 4 ur 1st, but if u really wana blow up throw 20-30mg of dbol in the mix for the 1st4-6wks. Also don't 4get about the most important things..... diet and pct.
If his diet is proper, and his exercise routine is intense, then I do not see any reason why he can't gain 15 lbs of lean muscle over 12 weeks on a a dose of just 250 mg per week. At the most, I would pin 250 mg every 5 days. My first cycle, 14 years ago, was 100-200 mg of Deca per week with 10 to 15 mg per day of Winstrol Tabs. This cycle was physician prescribed and I achieved phenomenal results. You do not want to blow your receptor sites up. You want to get the most out of the gear you use. Fight the mental battle, keep your dosing down!Somebody out there is working harder. Somebody wants it more.
