Originally posted by MrBig
View Post
GP Andromix
Negative, I was only taking the AAS that I outlined in the thread earlier. I am now on a Biomex Cycle of Sustanon, EQ, and Oral Turinabol. I will be throwing in the Gen Shi Cut Stack for the last 8 weeks! Im interested in using GH when I get a little older. Im in my early 30s now...Somebody out there is working harder. Somebody wants it more.
I would start with 1cc EOD and see how you feel. I get tremendous results from this and almost no sides from the Tren Ace other than sleep deprivation at that dosage. I have never felt the need to go up from there... Im excited about getting to the Cut Stack / Andromix portion of my current cycle. Ill keep ya posted...Somebody out there is working harder. Somebody wants it more.
I did not use an aromatase inhibitor, but instead went with Femara (Letrozole) at 2.5 mg E4D. In hindsight, I would have reduced this dosage. I ended up with a lot of back pain. I was running EQ at the same time last cycle. I discontinued EQ 2 weeks prior to the discontinuing the Cut Stack. I then waited 2 additional weeks before jumping on to PCT with 200 mg of Clomiphene. I stair stepped down over the course of the following 4 weeks and then hopped back in the boat!Somebody out there is working harder. Somebody wants it more.
Krazy you seem extremely intelligent with Andromix. I have have 2 20% off codes and 1 5% off code from our sponsor. for a first time user of gp andromix you only recommend 1cc eod (150mg eod) this would be my 5th cycle so I am in no way a newbie other than my status with this forum. Because I'm 26 would I want to use 2cc eod or is it really that potent that I only need 1cceod? 1cc eod is only 200mgs per week of each compound. I"m not saying you're wrong or calling you out but I am just wanting to confirm your post because I will be ordering gp andromix next week. Thank you for your info on this product too by the way much respect!!!
Im more than open to criticism. I am not an MD nor do I have a PHD, so I do not have a large ego when it comes to my knowledge and anecdotal experience. I had tremendous results with GP Andromix and Gen Shi Cut Stack at 1 ml EOD with 400 mg of EQ per week running in the background. Tren Ace, Test Prop, and Drost Prop are all very powerful fast acting compounds. Why burn your receptors in at 2 ml per when 1 ml per will provide very similar results. Also, 5 cycles certainly does not make you a newbie, but Im 32 on my 13 cycle... If I can still get great results with this dosage, you should as well, but ultimately, you will have to feel it out or get blood work. I MUST AGAIN STRESS, stay as low in dosage as you possibly can!!! Good Luck Bro!
Hey Krazy I was gonna run my cut stack at 1.5 EOD but since reading your post I figured I'd give 1 EOD a chance.. I also have 100 T3 pills and 100 clen.. Im not sure if I could/should stretch out the T3 over the 8 weeks(was gonna be 6) so would it be better to add the T3/clen later? Start it all together until I run out? Or just lower the dosage of the T3 to make it last the whole cycle? Any would be great. From anyone lol thanksOriginally posted by Krazy View PostIm more than open to criticism. I am not an MD nor do I have a PHD, so I do not have a large ego when it comes to my knowledge and anecdotal experience. I had tremendous results with GP Andromix and Gen Shi Cut Stack at 1 ml EOD with 400 mg of EQ per week running in the background. Tren Ace, Test Prop, and Drost Prop are all very powerful fast acting compounds. Why burn your receptors in at 2 ml per when 1 ml per will provide very similar results. Also, 5 cycles certainly does not make you a newbie, but Im 32 on my 13 cycle... If I can still get great results with this dosage, you should as well, but ultimately, you will have to feel it out or get blood work. I MUST AGAIN STRESS, stay as low in dosage as you possibly can!!! Good Luck Bro!
