GP Andromix
  • #31
    Originally posted by MrBig View Post
    As to adding more Test to the Andromix, I would say no everything is in it that you need for cutting. Unless you want to add some Clen with the cycle.
    Clen/t3 would make you look like the hulk with tht cycle
    • #32
      Very nice Krzy! Looking good bro!
      I have been a huge advocate of Andromix/Cut Stack. Its definitely one of my favorites
      • #33
        After reading this im going to buy 3 bottles of andro mix and and 2 bottles of eq that should be enough to run it for 12 weeks right?
        • #34
          Krazy are you also taking GH? or just what you said?
          • #35
            Negative, I was only taking the AAS that I outlined in the thread earlier. I am now on a Biomex Cycle of Sustanon, EQ, and Oral Turinabol. I will be throwing in the Gen Shi Cut Stack for the last 8 weeks! Im interested in using GH when I get a little older. Im in my early 30s now...
            • #36
              Krazy so you would only inject 1cc of andromix eod? Uncle's site says to use 1cc ed or 2cc eod..which should I use? This will be my first venture with andromix but not my first tren cycle. Thanks for your time!
              • #37
                I would start with 1cc EOD and see how you feel. I get tremendous results from this and almost no sides from the Tren Ace other than sleep deprivation at that dosage. I have never felt the need to go up from there... Im excited about getting to the Cut Stack / Andromix portion of my current cycle. Ill keep ya posted...
                • #38
                  krazy, i was wondering if you took AIs with the cut stack and how long after your cycle you started pct?
                  • #39
                    I did not use an aromatase inhibitor, but instead went with Femara (Letrozole) at 2.5 mg E4D. In hindsight, I would have reduced this dosage. I ended up with a lot of back pain. I was running EQ at the same time last cycle. I discontinued EQ 2 weeks prior to the discontinuing the Cut Stack. I then waited 2 additional weeks before jumping on to PCT with 200 mg of Clomiphene. I stair stepped down over the course of the following 4 weeks and then hopped back in the boat!
                    • #40
                      thanks for the help, i recieved the cut stack now i am just waiting on part two..i dont want to start and then be shit out of luck if i get done and not have the pct
                      • #41
                        Krazy you seem extremely intelligent with Andromix. I have have 2 20% off codes and 1 5% off code from our sponsor. for a first time user of gp andromix you only recommend 1cc eod (150mg eod) this would be my 5th cycle so I am in no way a newbie other than my status with this forum. Because I'm 26 would I want to use 2cc eod or is it really that potent that I only need 1cceod? 1cc eod is only 200mgs per week of each compound. I"m not saying you're wrong or calling you out but I am just wanting to confirm your post because I will be ordering gp andromix next week. Thank you for your info on this product too by the way much respect!!!
                        • #42
                          Im more than open to criticism. I am not an MD nor do I have a PHD, so I do not have a large ego when it comes to my knowledge and anecdotal experience. I had tremendous results with GP Andromix and Gen Shi Cut Stack at 1 ml EOD with 400 mg of EQ per week running in the background. Tren Ace, Test Prop, and Drost Prop are all very powerful fast acting compounds. Why burn your receptors in at 2 ml per when 1 ml per will provide very similar results. Also, 5 cycles certainly does not make you a newbie, but Im 32 on my 13 cycle... If I can still get great results with this dosage, you should as well, but ultimately, you will have to feel it out or get blood work. I MUST AGAIN STRESS, stay as low in dosage as you possibly can!!! Good Luck Bro!
                          • #43
                            Completely off Krazy I am going with about 10 weeks of andro 1 ml eod. Seems a bit low but worth a shot. Perhaps I have been wasting gear. This is still 500 mg a week on average.
                            • #44
                              Thanks for your time Krazy paying for my goodies next week ordering 3 vials of andromix gonna run it for 6 weeks and see how I react to it. If I do good I'll order more but best to start of low and build up as with anything. Thanks again and keep me posted on yours as well!
                              • #45
                                Hey Krazy I was gonna run my cut stack at 1.5 EOD but since reading your post I figured I'd give 1 EOD a chance.. I also have 100 T3 pills and 100 clen.. Im not sure if I could/should stretch out the T3 over the 8 weeks(was gonna be 6) so would it be better to add the T3/clen later? Start it all together until I run out? Or just lower the dosage of the T3 to make it last the whole cycle? Any would be great. From anyone lol thanks
                                Mclovin13
                                Member
