Cutting cycle help??
  • #16
    Thanks guys.
    • #17
      ouch
      This is a first cycle so naturally one would ask for help. No matter how much you read doing a cycle can get be very confusing. Most of the advice on here come from experienced users and in most cases they are not scientists or Doctors. Yes it would be great if everybody had the same advice but that's hardly the case. As far as PCT I have read posts here where Moderators totally disagree with each other. You would think these guys know their stuff, and Yes they Do but when a newbie sees so many Different opinions on PCT what should he think? Nolva Only, Clomid and Nolva, HCG during or after cycle? Arimidex, most say it should not be used PCT but some use it. Sometimes the more you read here the more confused you get so don't feel so bad cause everyone does it a little different then everyone else. Wow, lol they were kinda harsh huh.
      sigpic
      • #18
        Everyone's body is made up differently. What works for some doesn't work for others. This why we have a board to share experiences. I would concur with Bluelabel on the PCTadvise.
        • #19
          I earned the handle OLD DUDE because I am old(er) @ 63. Sorry I was rough, A lot of kids on lately, who need to learn that AAS is not a magic potion. Hard work,dedication, & proper diet will get you very far. Good Luck
          • #20
            So very true!! Yes AAS helps, but everything else needs to be in place first!
            " Defeat is not the worst of failures. Not to have tried is the true failure "
            • #21
              Originally posted by Youngin View Post
              Let me try this again. I hope this is a lil better educated question...
              ***8wk cycle, 1-8 WK-1mL Test Prop (EOD), 3-8WK 40mg of Winstrol, 1-11WK .5mg of Armidex. (Milk Thistle/Liv52) to help liver. For PCT, Clomid 5 days after last pin, for 4 weeks.. Since its moderate doses, I was thinking the Clomid would be enough?? I know the Arimidex will also help with PCT.
              I would substitute the Winstrol for Masterone ... As for PCT, you can use HCG throughout the cycle 2x a week 250iu each
