I found this chart, this should give you an idea where about you should be. You maybe bigger or smaller in some areas, but it's a good starting point.
INSTRUCTIONS
To use this chart first divide your bodyweight by your height in inches. (Example: If you are 150 lbs and you are 5 foot 9 inches (69 inches) then you would take 150 divided by 69) This will give your weight per inch of height. When this is determined select the figure in the far left column that is closest to yours. Then, follow the figures straight across to learn your ideal proportions. Women bodybuilders may have to adjust measurements in the area of hips, waist, and chest depending on build.
WT/HT Neck Biceps Forearm Chest Waist Hips Thigh Calf
1.90 14.00 13.10 10.90 36.40 27.30 32.80 19.70 13.10
1.97 14.25 13.35 11.10 37.15 27.85 33.45 20.05 13.35
2.04 14.50 13.60 11.30 37.90 28.40 34.10 20.40 13.60
2.11 14.75 13.85 11.55 38.60 28.90 34.70 20.80 13.85
2.18 15.00 14.10 11.80 39.30 29.40 35.30 21.20 14.10
2.26 15.30 14.35 12.00 40.00 29.70 35.95 21.60 14.35
2.33 15.60 14.60 12.20 40.70 30.00 36.60 22.00 14.60
2.41 15.85 14.85 12.40 41.40 30.80 37.25 22.35 14.85
2.49 16.10 15.10 12.60 42.10 31.60 37.90 22.70 15.10
2.57 16.40 15.40 12.85 42.80 32.10 38.55 23.10 15.40
2.65 16.70 15.70 13.10 43.50 32.60 39.20 23.50 15.70
2.73 16.95 15.95 13.30 44.25 33.15 39.85 23.90 15.95
2.82 17.20 16.20 13.50 45.00 33.70 40.50 24.30 16.20
2.90 17.50 16.45 13.70 45.70 34.25 41.10 24.65 16.45
2.99 17.80 16.70 13.90 46.40 34.80 41.70 25.00 16.70
3.09 18.05 17.00 14.15 47.20 35.40 42.45 25.45 17.00
3.20 18.30 17.30 14.40 48.00 36.00 43.20 25.90 17.30
3.29 18.55 17.55 14.60 48.70 36.55 43.85 26.30 17.55
3.38 18.80 17.80 14.80 49.40 37.10 44.50 26.70 17.80
INSTRUCTIONS
