Beginner:
1. One that begins something
2. An inexperienced person
3. One who has yet to learn the basic founding principles
4. One who has never trained with serious intent
***Note***
-There is an exception for some who will follow this beginner?s outline. Someone who has trained, who has lived a disciplined lifestyle such as this at some point in there life, but has for whatever reason turned away and finds themselves back at square one. For this person, they should consider themselves as the above definitions state if they are to truly meet their goals.
You?ve finally reached a point in your life where you?re ready to get into shape. You may be young you may be old, either way you?ve made the right choice. There is a good chance you?re here because you are ready to pile on pounds and pounds of muscle. There is a good chance you?re here because it is time to lose the fat and simply get into shape. Finally there is a chance that you realize that your overall health is of a greater importance than anything else; hopefully, no matter who you are, for the sake of your own wellbeing, no matter why you?re here your overall health comes into play. As a beginner, you probably have a vast array of questions; thankfully for you, you?ve come to probodybuilding.com and we have the answers.
No matter your goal, physical exercise along with a sound diet is one of the best things you will undertake in your life. With regular physical exercise and proper nutrition, you will make your immune system stronger, lower your risk to diseases such as heart disease, cardiovascular disease, type-2 diabetes and the most prevalent disease in our world today, obesity. If this is not enough reason, on top of that, regular physical exercise coupled with a sound diet does in fact improve your overall mental health and in many cases can prevent or help cure depression. Regular exercise seems to have a very positive effect on mental functions and capacity. Studies have shown that regular exercise can have a positive effect on neurodegenerative and neuromuscular diseases. Further, regular exercise can in fact reduce damage to or even reverse alcohol abused induced brain damage.
Whoever you are, no matter what your goals, the following outlines will start you down the right path. Many will read this nutritional outline and at first glance be left with many questions and doubts. Such questions and concerns might be:
Q: I want to ?Get Big? how is this enough food, enough calories? Shouldn?t I be eating like there is no end in sight?
A: You?ve just begun, chances are you already carry too much body fat, if not, chances are you?re not used to eating multiple meals per day; if you are, the odds are slim that you?ve had proper nutritional intake planned out in your diet. Following this outline you will ensure you don?t add tons of extra body fat; you will accustom your body to proper nutritional intake. For the first time in your life, you?ll be eating correctly, feeding your muscle the nutrients they crave.
Q: Isn?t there too much fat in this diet?
A: Fat is an important tool in our diets; the right fats. This is discussed in the outline.
Q: What about carbs, how can I train effectively on this amount of carbs?
A: As it was mentioned with calories, you are new to this game. If you are overweight or if you are what we call ?physique overweight? then excess carbs, sure you may be able to push more weight, but you will get fat. If you are in fact a hard gainer, then yes, you will need more carbs. If this is the case, see the ?Hard Gainer? outline at the bottom of the page.
Q: The big ripped guy at my gym said I need to eat everything in sight, he said that?s how he does it, why shouldn?t I listen to him?
A: Just because this is the way this guy does it, does not mean you should too. The odds are slim, very slim that he ate like he does now when he first started, sure there are exceptions, but these are the genetically gifted and few fall into this camp.
Q: My trainer says if I eat like it says in this diet I?ll get too fat, he says that I shouldn?t eat any more than 1200 calories per day. Who?s right?
A: There are good trainers and bad trainers. All trainers, no matter what they tell you are first and foremost there to make money. There is nothing wrong with this, they have to make a living too. But some trainers will sacrifice efficiency for fast short term results. If they starve their clients enough and drive them hard in the gym, the scale will go down, their clients may even shape up a little bit, but as a result, it will be at the expense of excess muscle loss, and cause long term metabolism failures.
***Note: This diet is designed assuming all things are perfect. Assuming that the individual who will use this diet is following all guidelines perfectly, is in perfect health, has had a positive genetic response to the beginner diet, and is not someone who suffers from some type of metabolism dysfunction.
***Beginners Meal Plan***
Meal 1:
-8 egg whites or liquid equivalent
-2 whole Omega-3 eggs
-1/2 cup of oatmeal
Or:
-40 grams whey isolate powder
-1tbsp natural peanut butter
-1/2 cup of oatmeal
When time is a factor first thing in the morning, simply mix in a shaker bottle your 40g of whey, 1tbsp of PB and your oats. Shake and drink. It may sound unappealing but you?ll find it?s not that bad.
Many will choose to simply drink their egg whites for convenience. Sounds gross but they have no taste. Use actual egg whites, not egg product.
KCL: 430-480, PT: 40-45, Carb: 40-45, Fat: 10-12
Meal 2:
-40 grams whey isolate powder mixed in water
-2tbsp of natural peanut butter
Or:
-6oz filet or lean beef
-green vegetables or green salad
Peanut butter mixes easily with your whey. You do not have to do this but doing so is fine.
How you cook your steak makes no difference. Grilled, baked or pan cooked with Pam is great.
Green vegetables should not have added ingredients such as cheese or butter.
KCL: 400-450, PT: 40-45, Carb: 5-10, Fat: 20-25
Meal 3:
-8oz chicken breast, turkey or fish
-1/2 cup rice
-1oz almonds or cashews
-green vegetables
Or:
-1 sweet potato
-green vegetables
Baking, grilling or boiling your chicken is the easiest. Cook enough to last you several days as well as the rice.
Sweet potatoes can be cooked quickly in the microwave. Just poke a few holes in the skin with a knife or fork
KCL: 575-600, PT: 40-50, Carb: 30-35, Fat: 20-25
Meal 4:
-Same as meal 1 or 3
-If meal 1 option 2, add an extra tbsp of PB
Mix it up to help with variety
KCL: 530-600, PT: 40-45, Carb: 40-45, Fat: 18-25
Meal 5:
-Same as meal 2
Vanilla or fruit flavored protein mixes well with Crystal Lite
Meal6:
Or:
- 6oz filet or lean beef
Or:
-40 grams whey isolate mixed in water
-2tbsp natural peanut butter
Last meal of the day, it should be eaten not too far off before bedtime. Being hungry before you go to bed is never any fun.
There are no carbs in this meal since you don?t need them. You?ve already trained.
KCL: KCL: 450-480, PT: 40-45, Carb: 0-10, Fat: 10-20
Daily Totals:
Calories (KCL): 2785-3060
Protein (PT): 240-275
Carb: 120-150
Fat: 98-132
*Note: Diet does not take into account carbs from green vegetables. This will take your carb total over the amount listed but don?t let this worry you at all. Good news is, although on paper it looks very low in carbs, you will have more then enough energy to train. Further, you will be eating a substantial amount of ?Good? fat to fuel your training more then adequately.
All-in-all, this diet is designed to get you going in the right direction, so as to not put on too much fat. In fact some will see their body fat go down and more importantly, all will learn how to eat.
***Note***
Meal 1:
-1/2 cup of oatmeal
Or:
-1/2 cup of oatmeal
Meal 2:
Or:
Meal 3:
-1/2 cup rice
-green vegetables
Or:
-1 sweet potato
-green vegetables
Meal 4:
Meal 5:
-Same as meal 2
Meal6:
Or:
Or:
Daily Totals:
Carb: 120-150
Fat: 98-132
