i have some Axio labs
  • i have some Axio labs
    any advice you guys can give is good..ive had these 2 bottles for awhile and about to start them
    has anyone used or seen anything from axio labs? im new in here
      what is it? axio is a brand, not a drug. do you have an AI and PCT lined up?
        I used Axio several years back before they went down.... The tren was strong, and the test seemed to be pretty good. If you got it recently I couldn't really comment on the quality....
          hold on ill grab them and look..and yes i got them afew years ago and never used them but there still good. the exp date is 2013
            deca 300 sust 325 and no i have not decided what to do.its been afew years sence i last did any
              it worked real good the first time i started....but im not big as you guys i guess i was not born to get naturaly big so i went another direction
                wait... you have one of each and you wanna start? you do realize you don't even have a fourth of what you need for a cycle?
                  being that you've been off for a while imo run it 1cc of each a week and you should make good gains. I have good gains with the same combo different brand but same product. i'm only at 270ml sus/250ml deca and have gained 6lbs in just under 2 weeks. I have no sides so far as they are dose related. low dose low sides.
                    I had some axio sust325 2 years ago and the inj. site felt like getting kicked by a horse the day after. I think they use a ton a alcohol. I recommend you get some new stuff if you get the same batch i had.
