PLEASE READ AND READ OVER AND OVER UNTIL YOU UNDERSTAND. AFTER DOING THAT YOU WILL HAVE AND IDEA ON TIMING, AMOUNT, TO USE FOR A HGH CYCLE.
Lately, my pms have been full with these same questions about an HGH cycle. Beaware it is more than just hgh and slin, that you need to make this cycle work well. When done right that is the differnt look that you see in Pros and National competors compared to the average guy that just does juice. This is what seperates us from you. But you must spend the cash and do it right. I'm not going to half butt this. This is one of my ways, that could easly help you. I will use a normal dose that would help many. (REMEMBER MY WAY MAY NOT AND IS THE THE RIGHT OR ONLY WAY, SO GRAB WHAT HELPS YOU). The best way to learn is read and study about the drug and trial and error. ONE THING THERE IS NO ROOM FOR TRIAL AND ERROR WITH INSULIN, TO LITTLE IS BETTER THAN TOO MUCH!!!! NOT A DOCTOR SO READ AND STUDY AND ASK QUESTIONS. HGH shoild be done 30-30 wks or 6 months to as long as you can afford it.
Cycle:
Weeks 1-20-30 HGH on 5 days off 2
2-2.5 ius upon rising in the am.
2-2.5 ius early afternoon
( you can inject it sub-c into abs, obliques, front thights, upper tris.
Weeks 1-5, 11-15, 21-25 Long IGF-1 everyday.
60 mcgs intramuscular /post workout on workout days
First thing in the mourning on non-workout days.
Weeks 6-10, 16-20, 26-30 humalog (only on workout days)
8iu's immedialtely post workout, intramuscular (you can run humalog on 1-5,11-15,21-25, with LR3 if you perfered.
EXPLAINING HUMALOG INJECTION( PLEASE PAY ATTENTION)
RIGHT AFTER INJECTION
INJECTION 5 MIN- DRINK SHAKE WITH 10G GLUTAMINE/10G CREATINE/55G DEXTROSE
INJECTION 15 MIN LATER DRINK SHAKE WITH 80G OF WHEY PROTEIN IN WATER
INJECTION 60-75 MINS EAT A PROTEIN / CARB MEAL WITH 40-50 GMS OF PROTEIN, 40-50 GMS CARBS, NO FAT!!!
AVOID FATS 2-3 HOURS IF INJECTION WAS INTRAMUSCULAR. 3-4 HOURS IF INJECTED SUB-Q. 4-5 HOURS IF USED HUMULIN-R.
KEEP SOME GLUCOSE TABS OR SIMPLE CARBS ON HAND FOR THE ACTIVE WINDOW OF YOUR INSULIN. HYPO SYMPTOMS COULD HIT QUICK AND HARD AND YOU WILL HAVE LITTLE TIME TO REACT. (THIS IS THE MAIN DANGER OF INSULIN USE)!
T-3:
WEEKS 1-5, 11-15, 21-25 12.5 MCG -25 MCG PER DAY OR 100-150 MCGS USE THIS AMOUNT IF GOING FOR FAT LOSS INSTEAD OF PROTEIN SYNTHESIS.
I WILL BREAK IT DOWN TO YOU
HGH:
SHOULD BE USED 20-30 WEEKS OR 6 MONTHS OR LONG AS YOU CAN AFFORD. iF SHOOTING FOR FAT LOSS, USE 2-2.5 PER DAY IF USING FOR FAT LOSS, 4-5 IU'S A DAY FOR FAT LOSS AND MUSCLE GROWTH. FEMALES 1-2 IU'S A DAY. SPLIT DOSE 1/2 UPON WAKING UP AND OTHER HALF EARLY AFTERNOON, IF YOUR DOSE IS ABOVE 2.0 IU'S. YOUR PITUITARY MAKES ABOUT 10 PULSES BY IT'S SELF OF GH PER DAY. SO EACH INJECTION WILL REPORT A NEGATIVE FEED BACK LOOP THAT WILL SUPPRESS THESE PULSES FOR ABOUT 4 HOURS. BY TAKING IT IN THE SPLITS I MENTION WILL STILL ALLOW YOUR BODY TO RELEASE IT'S BIGGEST PULSE, WHICH MOSTLY OCCURS SHORTHLY AFTER GOING TO SLEEP AT NIGHT.
WHENFIRST STARTING OUT START WITH A DOSE OF 1.5-2.0IUS PER DAY FOR A COUPLE OF WEEKS, THEN INCREASE YOUR DOSE BY 0.5-A.0 UNITS EVERY WEEK OR TWO UNTIL YOU REACH YOUR DESIRED LEVEL. YOU DON'T HAVE TO DUE THIS. BUT IF YOU ARE SENSITIVE TO THE SIDES OF HGH, PAIN, SWELLING AND BLOATING, WATER RETENTION, BY SLOWLY ACCLAIMATING TO YOUR DESIRED LEVEL YOU MAY AVOID THIS.
USE A U100 INSULIN SYRINGE FOR INJECTING .
IGF-1
WHEN THE HGH GOES THROUH THE LIVER, A RELEASE OF IGF-1 IS A RESULT. IGF-1 IS SAID TO BE THE MAIN PLAYER IN MUSCLE GROWTH. IT STIMULATES BOTH THE DIFFERENTIATION AND PROLIFERATION OF MYOBLASTS. IT STIMULATES AMIO ACID UPTAKE AND PROTEIN SYNTHESIS IN THE MUSCLE TISSUES. HGH CAUSES AN INCREASES IN IGF-1 LEVEL OVER A COURSE OF A FEW MONTHS, HGH HAS A CUMULATIVE EFFECT, SO THE EXTRA IGF-1 WILL GREATLY SPEED UP THE TIME TO RESULTS.
THERE ARE TWO TYPES OF IGF-1 THAT WE USE. ONE IS BIO-IDENTICAL HUIGF-1 A 70 AMINO ACID STRING. THE OTHER IS LONG R3 IGF-1, WHICH IS AN 83 AMINO ANALOG OF HUMAN IGF-1 COMPRISING THE COMPLETE HUMAN IGF-I SEQUENCE WITH SUBSTITUTION OF AN ARG FOR THE GLU AT POSTION 3 (HENCE R3), AND A 13 AMINO ACID EXTENSION PEPTIDE AT THE N-TERMINUS (HENCE THE LONG). WHICH OF THESE IS PICKED BY YOUR GOAL. THIS TYPE OF IGF-1 IS VERY USEFUL, FOR LOCAL SITE GROWTH, IT IS ALSO SHORT LIVED, LITTLE OF THE IGF-1 MAKES IT TO OTHER TISSUES AND IGF-1 RECEPTORS IN THE BODY. YOU SHOULD INJECT THIS POST WORKOUT INTO THE MUSCLE THAT YOU WANT TO HAVE LOCAL SITE GROWTH. iNJECT U100 INSULIN SYRINGE AND 80MCG'S BILATERALLY INTO THE CHOICE AREA MUSCLE IMMEDIATELY POST WORKOUT. FOR THIS TYPE OF IGF-1, USE WORKOUT DAYS ONLY , IF YOU WANT YOU CAN INJECT FIRST THING IN MOURNING ON NON WORKOUT DAYS, INTO THE MUSCLE GROUP WORKED THE PREVIOUS DAY.
LONG R3 IGF-1, YOU MUST INJECT INTO A LOCAL SITE IT HAS A ACTIVE LIFE OF MANY HOURS AND IS DESIGNED SPECIFICALLY TO RESIT BEING BOUND. IT IS COMMON TO RECONSTITUTE THIS TYPE OF IGF-1 WITH BENZYL ALCOHOL, ACETIC ACID, OR HYDROCHOLIC ACID, I WOULD STILL INJECT INTRAMUSCULAR. IT MAY LIVE A RED IRRITATED SPOT IF INJECT SUB -C. INJECT INTO MUSCLE JUST WORKED TO TAKE ADVANTAGE OF INCREASED IGF-1 RECEPTORS, BUT BECAUSE OF THE LONG ACTIVE WINDOW THIS TYPE OF IGF-1 WILL WORK IN ANY MUSCLE AND GIVE GOOD RESULTS. INJECT 40-80MCG PER DAY EVERYDAY, RIGHT AFTER POST WORKOUT ON WORKOUT DAYS, AND FIRST TING IN MOURNING ON NON WORKOUT DAYS.
INSULIN;
WHEN WE WORK OUT WITH WE END UP IN A CATABOLIC STATE. IT IS IMPORTANT TO BACK IN A POSTIVE NITROGEN BALANCE ASAP. WHEN NOT USING INSULIN WE DRINK DEXTROSE WITH OUR PROTEIN TO CAUSE INSULIN SPIKE IMMEDIATELY POST WORKOUT TO HELP SHUTTLE THE PROTEIN AND SURGARS TO THE MUSCLES.
INSULIN IS VERY GOOD FOR PUSHING NUTRIENTS TO THE MUSCLES AND WORKS IN A VERY COMPLIMENTARY MANNER WITH GH IN THE TYPE OF THINGS THAT THEY SHUTTLE. HGH CAN CAUSE AN AMOUNT OF INSULIN RESISTANCE THAT MIGHT OCCUR DURING YOUR HGH USE.
USING A DOSAGES OF 4-10 UNITS, IS GOOD AND SHOULD BE USED RIGHT AWAY POST WORKOUT. HUMALOG SEEMS TO WORK THE BEST, IT CAUSE A PAPID SPIKE AND CLEAR OUT THE SYSTEM QUICKLY. yOU CAN USE IT SUB-Q OR USE HUMULIN-R INSTEAD, BUT EACH WILL RESULT IN A LONGER ACTIVTY WINDOW, THUS LONGER TIME TO AVOID EATING ANY FATS AND WATCHING FAT DURING INSULIN'S ACTIVE WINDOW. THE WINDOW ARE LISTED BELOW
HUMALOG -IM 3-4 HOURS
SUB-Q-R IM 3-4 HOURS
HUMULIN-R IM 3-4 HOURS
SUB-Q 4-5 HOURS
IF YOU DO NOT WISH TO USE INSULIN, POST WORKOUT YOU CAN SPIKE YOUR OWN ENDOGENOUS INSULIN BY DRINKING 80 GRAMS OF DEXTROSE/40 GRAMS OF WHEY ISOLATE PROTEIN. IT IS NOT INSULIN BUT IT WILL DO THE JOB GETTING NITROGEN POSTIVE ENVIRONMENT IN A SHORT AMOUNT OF TIME.
T-3
HGH CAN HAVE A SLIGHT INHIBITORY EFFECT ON YOUR THYROID. MOST WILL NEED JUST A SMALL AMOUNT 12.5. HOPE I HAVE HELPED YOU. ANY QUESTIONS GOOD LUCK.
Cycle:
T-3:
HGH:
IGF-1
INSULIN;
SUB-Q 4-5 HOURS
T-3
