Gp andromix feedback
  • Gp andromix feedback
    Any one got experience with ?
    I've run it a once before and am 3 weeks into another run with it. Personally, I think its amazing stuff, but I only get the gains from tren, neither time were the sides crippling or as debilitating as most people say. I think a lot of the tren sides stories are a combo of regurgitated rumors and people allowing their mind to make sides worse than they really are. But then again, I suppose I could just be 1 in a million, but I definitely recommend it
      excellent product, i run a cycle with andromix 1 cc per day for 10 weeks,i lower my BF 6-7% with very clean diet and i gain 6 kg...
        What else do you run with it my friend?
          @Quadzilla420,
          The Trenbolone that is used in the Andromix is Trenbolone Acetate, which does not produce the side effects as would the Trenbolone Enanthate. Because the Trenbolone Acetate is a shorter ester most guys wont, get some of the side associated with the Trenbolone. Trenbolone Enanthate is a longer ester which stays in the body longer, allowing it to cause more issues. From experience I find that if I use 400mg's or more of Trenbolone Enanthate, I find the side start for me at that dose. Usually night sweats and the fucked up dreaming.
          Chat Box Talk And Rules
            If i take 1 cc a day should i also add a little more test prop?
              ritethe1sttim, I can't say with out knowing how many cycles you've done and what your looking to accomplish with the cycle.
                where is the best website to buy gear with no issues plz help
                  I have done 3 test only cycles... One test winstrol cycle and one dbol test winstrol cycle. I want to try tren and i got a good price on andro mix. I have read to add .5 cc of prop a day to cycle. Just wanted to know some more experienced users opinions are to this rout.
                    Here is a list u choose... https://www.eroids.com/info/based/us-domestic
                      Those are all domestic so no customs. This means faster delivery but more expensive. Do research its easy to figure out.
                        BEST PLACE TO GET ANDRO MIX OR ANY CUT STACK .... This is the best service that you can get always on top of everything.. You guys are so honest with your business. I will always order from naps I get all my friends to order from naps .. The quality of your goods are always top notch I always get good results with the gear .. The orders and service is awesome.. If any of you guys are hesitant about ordering don't be follow the steps and they will come thru..naps has helped me reach my goals.. So it time to set some more ..
                        So thank you napsgear for doing what you do.
                          I don't suggest running Andromix, purely for the fact, if you have sides and need to adjust, there are three compounds in it that you are adjusting. You really should run just Tren Ace (along with test and whatever you want) but if the tren is too much, you can adjust that by itself.
