Moderately's turn to cycle many times a year?
  • Moderately's turn to cycle many times a year?
    hello bro
    I'm 171cm 78kg age 29, The weight of the cycle before dead 175kg fullsquat 160kg bench 100kg.
    I started the first cycle of just now. In TEST-E W 500mg stack. Over the first cycle(Including PCT), can I do when starting a second cycle? And I prefer to stack mild. The first was a TEST E alone, and the second is to to do with the TEST E + TREN E cycle
    Lay off the tren until later off man. No need to add another compound let alone one as serious as tren. Look into an oral kick start say dbol or tbol depending on goals. No offense man but you should research more before jumping into a tren cycle for the second one. Just my opinion but at the end of the day it's your decision. Best of luck..
      Yeah. There's a lot of new people who want to do tren right off because it's a bad mo fo, but if you don't know what you're doing your dick with fall off and wash down the shower drain. True story....
      Keep it simple at first.
      Lucky rabbits are without their feet
