anavar question
  • anavar question
    I plan on adding some var to my next test/eq cycle was wondering how much for how long. I was thinking like 60mg per day for first 5-6weeks. Or should it be run at the end of cycle. Cycle will be 16 weeks. Also should var dose be split or all at once. Thanks in advance
    Quadzilla420
    Member
    Based off of what we were talking about before, I'd use it in the second half of the cycle, as you get leaner. 50mg is pretty standard. I'd run it for the last 8 wks, split into 2 daily doses
      Posted this on another thread, can't remember where I found it, good read though.
      MYTHS
      Myth #1 - Anavar will not suppress the HPTA.
      False. Anavar, used in adequate dosages, will shut you down. To what degree you experience side effects of suppression (loss of libido, lethargy) is entirely dependent upon the individual and the dosages used.
      Myth #2 - Var is a weak anabolic, and is not effective unless stacked with a more androgenic compound.
      This could not be further from the truth. At dosages of 40mg a day and higher, anavar is incredibly effective at adding water free LBM. At around day 6-7, increased vascularity should become apparent (assuming your oxandrolone is legitimate in its dosing), and strength gains should start appearing around day 14.
      If used during a clean bulk, gains of 10-20 pounds are possible. If cutting, you will maintain weight, or even put on 5-10 pounds (depending on the rate of fat loss/severity of diet). You will keep all of your gains with proper PCT.
      Myth #3 - Anavar will not require any type of PCT.
      This is one ive never understood. It's a pretty commonly known fact now that var is a suppressive compound. So why is it that some individuals still refuse to make a small investment in some clomid/nolva....this is your testicular function we're talking about. That said, PCT required for var is not as "heavy" as PCT for, say, a test/eq cycle. 15-20 days @ 50mg clomid should be sufficient.
      LIBIDO
      The only real issue of concern that i have found when running anavar alone is slight libido suppression. Anavar is suppressive enough to where you WILL feel a difference in your sex drive (and not for the better ) when using 40+mg a day. There are three options to counteract this.
      #1 - Tribulus + Avena Sativa - Trib at 4-7g a day and Avena Sativa at 3-4g a day tend to help prevent any loss in performance or ability to get it up. However, using effective dosages is going to end up being as or more expensive than options 2 or 3...but its your call.
      #2 - Proviron - If hairloss is an issue in your choice to use anavar, then you may want to avoid this one. But 25mg ED proviron, starting after week 2, will keep you rock hard. And it will help to harden up your muscles too .
      #3 - Maintenance Test Dosage - Finally, you could choose to use testosterone to keep your willy in shape. At a dosage of around 200mg, split bi weekly, everything should keep running smoothly. Also, this will contribute to your gains much moreso than than options 1 or 2. I would keep nolva onhand on the off chance that you are severely gyno prone. Bloating should not be an issue at this dosage.
      BENEFITS
      Anavar is a badass drug. This is why.
      #1 - Vascularity
      Oxandrolone will make you veiny as all hell. And quickly. Look out for brand new bulging forearms veins by around day 6. If you are following a cutting regimen, expect new spider webs in your chest, shoulders and quads by around day 21.
      #2 - Pumps
      When on var, the pumps are constant. Bored sitting in class/at work? Do some unweighted calf raises. After about three minutes, your calves will be ready to pop. Youll be doing something like drinking a cup of water, and after a minute of holding it, your bi will be completely full and pumped. You may have to cut some sets short in the gym due to the painful pumpage.
      #3 - Strength
      Even when cutting, you can expect new strength gains every workout after about day 14-21.
      #4 - Fat Loss
      Anavar has been shown to contribute to accelerated fat loss in both subcutaneous and visceral fat, concentrated effects in the abdomen and thigh area. And if youve used the drug, you can attest to this...if you cant sport the 6-8 pack look on var, its not gonna happen .
      CYCLE
      Anavar should be run @ at least 40mg a day to see all of the benefits it offers. Dosages upwards of 80mg have been shown to exhibit diminishing returns. Also, i cant imagine the intensity of the pumps at that kind of dosage.
      LIVER PROTECTION
      Anavar is a 17 Alpha Alkylated steroid, and is toxic. It has been shown to be less toxic than other orals, and is even used as liver treatment for recovering alcoholics. Still, i would limit my time using it to 8 weeks, 10 at the most.
      It would be beneficial to you liver to use several different OTC supplements during, and perhaps after your cycle. A few preventive measures never hurt anyone .
      1 - Milk ThistleThe classic liver protectant herb.supposedly works by blocking the entrance of harmful substances to liver cells, and hastening their expulsion. Make sure there is a high standardization of Silymarin
      2 - R ALA
      A powerful antioxidant
      3 - NAC
      Supports liver function and production of l-glutathione
      4 - Vitamin C and E
      Antioxidants
      5 - LOADS of water
      Helps to flush out your entire system
      LIPID PROTECTION
      Anavar isnt going to kill your cholesterol levels like some drugs (winny being one of the worst), but it may put your LDL/HDL profiles outside of the normal range. There are a few things that help, but as long as your not using 60+mg daily or running it for more than 10 weeks, i would just use flax...
      1 - Flax Oil
      Consuming lots of essential fatty acids promotes overall health, as well as helping to keep your lipid profile from becoming too bad.
      2 - Policosanol
      Used at 20mg daily to keep your HDL (good cholesterol) levels from crashing, and your LDL from becoming too high.
      3 - Niacin
      Preferably the flush free variety. If you wish, niacin can be used at 1-2g ED for a short period post-cycle to normalize HDL levels. Do not use for more than 7-14 days, as liver toxicity can be an issue when using those dosages of niacin for long periods of time
        nice find!
          Originally posted by sam1976 View Post
          nice find!
          Thanks Sam! From my experience it's pretty accurate, and var is under rated. Only issue I see with var is the cost at times, worth it IMO though.
            Yea, I used to be not that into var, but I'm coming around
              What dose do you like Sam? I stay at 50-60mg ED, anything higher and my lower back pumps interfere with training.
                I'm right with you. 50 mg is just fine. Especially for your average Gym goer, who is looking to do a noncompetitive cycle.
                sam1976
                  great read
