Stats 6ft 225lbs has never juiced. Barely works out wants to gain a little bit of muscle like maybe 15 -20lbs but the main thing wants to loose some belly fat. I heard tren/test would be good, what would anyone recommend for him?
Friend needs help first cycle
Well when I started using gear I was barely working out and my diet was crap, did sum research and commuted my self to it. I gained 40lbs on juice and I am happy with results. He has me as a guide but I used deca/ test and I heard that will not help loose body fat he wants to eat right but wants a little help for faster results. Can anyone help with anything he can use?
Originally posted by jj_tv View PostWell when I started using gear I was barely working out and my diet was crap, did sum research and commuted my self to it. I gained 40lbs on juice and I am happy with results. He has me as a guide but I used deca/ test and I heard that will not help loose body fat he wants to eat right but wants a little help for faster results. Can anyone help with anything he can use?"I COUNT HIM BRAVER WHO OVERCOMES HIS OWN DESIRE THAN WHO CONQUERS HIS ENEMIES, FOR THE HARDEST VICTORY IS OVER SELF"
Originally posted by jj_tv View PostStats 6ft 225lbs has never juiced. Barely works out wants to gain a little bit of muscle like maybe 15 -20lbs but the main thing wants to loose some belly fat. I heard tren/test would be good, what would anyone recommend for him?
I would not suggest to use tren for first cycle. Use a common dose of test-only like test-e 250/500mg a week/e5d depending on how old your friend ist for about 16-20weeks. I can hear all guys yelling at me now because 250mg is waaaaayyy too low, but I dont agree with that. Use minimum dose which works. AND DONT EVER THINK OF USING TREN IN THE FIRST 3-4 CYCLES ! You can add a d-bol kickstart the first 4 weeks but make sure youll use milkthistle or any liver protection also.
After test only cycle use a proper PCT consisting clom and maybe hcg.
Greetz
PS: and add in 20-30min cardio (walking WALKING on a treadmill) before EVERY workout
Originally posted by 123GetBigGER View PostI agree with the other guys posting before, but if he wants to start gear he'll probably will anyways.
Greetz
I wouldn't say don't do it. For me- I usually do light cardio for 15-20 mins before my lifting. I've been under the assumption that by warming up the muscles, increasing blood flow and HR- will yield just as good of results as if you were to do cardio after. I see a lot of dudes go right into lifting without a proper warmup and IMO you're not doing your body any good by starting your workout with cold and tight muscles/ joints. A proper warm up or light cardio session before a workout will prevent injury.
JM2C
-Nature"Whatever we plant in our subconscious mind, and nourish with repetition and emotion, will one day become reality."
NapsGear.Org - The Largest and Most Trusted!
Originally posted by Nature101 View PostI wouldn't say don't do it. For me- I usually do light cardio for 15-20 mins before my lifting. I've been under the assumption that by warming up the muscles, increasing blood flow and HR- will yield just as good of results as if you were to do cardio after. I see a lot of dudes go right into lifting without a proper warmup and IMO you're not doing your body any good by starting your workout with cold and tight muscles/ joints. A proper warm up or light cardio session before a workout will prevent injury.
JM2C
-Nature
