Collagen Synthesis/ EQ and other AS's
  • Collagen Synthesis/ EQ and other AS's
    I have big injury in a tendon, do boldenon or anavar good?
    Thanks
    Nobody want to speak about it, possible that all real bodybuider have injury a day and it is good to know what is better.
    I am going to make cycle with
    testosterone enanthate 250 mg
    boldenon 300 mg
    trenbolone enanthate 250
    after some month whent it was impossible to train because injury in my tendon I come back in the gym with this stack your opinion help me
    thanks
    bea
      While injecting test increases protein synthesis by roughly 50 times, depending on dose and time, most bodybuilders forget that it will reduce collagen synthesis by more than 50% -- more like 80%, giving you the collagen synthesis rate of a senior citizen. Since collagen makes up tendons, bros are very prone to injury if they continue to lift very heavy, unless they cycle off T and let their collagen synthesis get back to normal. It's like having the skeletal muscle of a gorilla with the tendons of a very old man.
      Winstrol increases collagen synthesis. It will give you bigger tendons. However, your body compensates for this by making them more brittle, weaker, and more prone to injury. I can't tell you how many bros work out anaerobically and become injured while on winstrol. Guys who lift in the 1-5 rep range while on winstrol, to baseball players who sprint all out from a stationary position -- winstrol should be the LAST drug they choose. Most of them like winstrol because they don't get the weight gain from it but it is very detrimental to bros who train for any sport anaerobically. Tendons tear easily on it.
      Also, the drugs I mention increase collagen synthesis while also increasing collagen cross-linking integrity, making for a much stronger tendon.
      Winstrol, on the other hand, will dramatically increase collagen syn, but ironically it decreases collagen cross-linking integrity, thus making a much weaker tendon.
      You can plan a cycle of anabolic steroids which will increase collagen synthesis and skeletal muscle growth at the same time. The key is the drug(s) you choose.
      Deca-Durabolin - nandrolone decanoate - , Equipoise, Anavar, and Primobolan will ALL increase skeletal muscle while at the same time dramatically increase collagen syn and bone mass and density, leaving you with a substantially reduced chance of becoming injured than if you choose to use anabolic steroids like sus, testosterone cypionate, or testosterone enanthate.
      While testosterone will increase bone mass and density, even at supra-physiological levels, the result is weaker tendons due to inhibition of collagen syn.
      To plan a cycle where the goal is to increase skeletal muscle mass/strength while at the same time increase joint/tendon/ligament strength, enough to keep up with the dramatic increase in skeletal muscle, you must choose drugs like Equipoise - boldenone undecylenate - , Deca-Durabolin - nandrolone decanoate - , Anavar, or Primobolan - methenolone - as the base of your cycle. testosterone and its esters can be added to your cycle to keep levels within a 'normal' physiological range (ie, 100-200 mg/wk) but must not go above this. Since drugs like Equipoise - boldenone undecylenate - , Deca-Durabolin - nandrolone decanoate - , anavar and Primobolan - methenolone - will reduce endogenous, natural levels of test, these levels may be maintained with exogenous test in the 100-200 mg/wk range. Test at this dose will not inhibit collagen syn, but paradoxically, will help increase it. It is when exogenous testosterone is used > 200 mg/wk that collagen syn is inhibited.
      Deca-Durabolin - nandrolone decanoate - @ 3 mg/kg a week(about 270 mg/wk for a 200 lb male) will increase procollagen III levels by 270% by week 2. Procollagen III is a primary indicator used to determine the rate of collagen syn. As you can see, Deca-Durabolin - nandrolone decanoate - is a very good drug at giving you everything you want -- an increase in collagen syn, an increase in skeletal muscle, and increases in bone mass and density. The one thing it does not give you is wood
      Primobolan, @ 5 mg/kg, will increase collagen synthesis by roughly 180% -- less than Deca-Durabolin - nandrolone decanoate - and equipoise but still substantial.
      Equipoise @ 3 mg/kg will increase procollagen III by approximately 340% -- slightly better than Deca-Durabolin - nandrolone decanoate - .
      Oxandrolone has over a hundred studies documenting its effectiveness at treating patients needing rapid increases in collagen syn to enhance healing.
      These drugs have longer half-lives than most other anabolic steroids, so this should be considered when timing your post cycle clomid use. Here they are:
      Deca-Durabolin - nandrolone decanoate - : 15 days Equipoise: 14 days Primobolan: 10.5 days
      Anavar has a half-life of only 8 hours so it should not pose a problem.
      gh - growth hormone (somatropin) - is probably the most remarkable drug at increasing collagen synthesis. It increases collagen syn in a dose dependant manner -- the more you use, the more you will increase collagen syn. It has also demonstrated this ability in short and long term studies. From what I've read, human growth hormone - somatropin - at 6 iu/day increased the collagen deposition rate by around 250% in damaged collagen structures. This result indicates that the increased biomechanical strength of wounds to collagen structures treated with biosynthetic human growth hormone was produced by an increased deposition of collagen in the collagen structures.
      Equipoise - boldenone undecylenate - , Primobolan - methenolone - , anavar, and Deca-Durabolin - nandrolone decanoate - are all good -- they increase several biomakers of collagen syn -- ie, type III, II, I, procollagen markers. gh - growth hormone (somatropin) - just seems to do so most dramatically.
      Use of any of these drugs @ supra-physiological levels with a maintenance dose of test will increase collagen syn while at the same time increase skeletal muscle mass. Skeletal muscle mass gains will not be as dramatic as with large testosterone doses but you have to weigh the risk/reward basis for yourself. Also, these drugs do not satisfy the libido like testosterone, but that is not the point of this thread. It is only to demonstrate that you can increase skeletal muscle and collagen syn at the same time with certain anabolic steroids, the decision is up to you.
        Although it goes against common "wisdom", it stands to reason that trenbolone does, in fact, stimulate collagen synthesis, thereby helping your joints.
        You see, trenbolone increases IGF-1 to a great degree, which ought to stimulate the growth of tendons, as we all know.
        Endocrinology. 1989 May;124(5):2110-7.
        Trenbolone alters the responsiveness of skeletal muscle satellite cells to fibroblast growth factor and insulin-like growth factor I.
        Thompson SH, Boxhorn LK, Kong WY, Allen RE.
        Department of Animal Sciences, University of Arizona, Tucson 85721.
        The potential role of satellite cells in mediating the effect of trenbolone [17 beta-hydroxyestra-4,9-11-trien-3-one (TBOH)] on skeletal muscle hypertrophy was examined. Young female Sprague-Dawley rats received TBOH injections daily for 2 weeks; growth, body composition, and the composition of selected muscles were assessed. Treated rats grew more rapidly and deposited less body lipid and more protein. The semimembranosus muscle from treated rats was larger and had approximately 60% more DNA per muscle than muscles from control rats. The addition of trenbolone directly to the medium of cultured satellite cells did not stimulate cell proliferation, nor did it augment the stimulatory response of these cells to fibroblast growth factor (FGF) or insulin-like growth factor I (IGF-I). In contrast, satellite cells cultured from TBOH-treated rats exhibited greater proliferative responses to FGF and IGF-I than satellite cells from control rats. In addition, serum from TBOH-treated rats stimulated greater cell proliferation in satellite cell cultures than serum from control rats. These experiments suggest that one possible mechanism responsible for the ability of TBOH to stimulate skeletal muscle hypertrophy may be through enhanced proliferation and differentiation of satellite cells as a result of the increased sensitivity of these cells to IGF-I and FGF.
        PMID: 2707149 [PubMed - indexed for MEDLINE]
        You will also note that trenbolone treated satellite cells showed an increased response to FGF (fibroblast growth factor). Again, as we know, (basic)FGF stimulates collagen synthesis:
        Sports Med. 2003;33(5):381-94.
        The roles of growth factors in tendon and ligament healing.
        Molloy T, Wang Y, Murrell G.
        Orthopaedic Research Institute, St George Hospital Campus, University of New South Wales, Sydney, Australia.
        Tendon healing is a complex and highly-regulated process that is initiated, sustained and eventually terminated by a large number and variety of molecules. Growth factors represent one of the most important of the molecular families involved in healing, and a considerable number of studies have been undertaken in an effort to elucidate their many functions. This review covers some of the recent investigations into the roles of five growth factors whose activities have been best characterised during tendon healing: insulin-like growth factor-I (IGF-I), transforming growth factor beta (TGFbeta), vascular endothelial growth factor (VEGF), platelet-derived growth factor (PDGF), and basic fibroblast growth factor (bFGF). All five are markedly up-regulated following tendon injury and are active at multiple stages of the healing process. IGF-I has been shown to be highly expressed during the early inflammatory phase in a number of animal tendon healing models, and appears to aid in the proliferation and migration of fibroblasts and to subsequently increase collagen production. TGFbeta is also active during inflammation, and has a variety of effects including the regulation of cellular migration and proliferation, and fibronectin binding interactions. VEGF is produced at its highest levels only after the inflammatory phase, at which time it is a powerful stimulator of angiogenesis. PDGF is produced shortly after tendon damage and helps to stimulate the production of other growth factors, including IGF-I, and has roles in tissue remodelling.In vitro and in vivo studies have shown that bFGF is both a powerful stimulator of angiogenesis and a regulator of cellular migration and proliferation. This review also covers some of the most recent studies into the use of these molecules as therapeutic agents to increase the efficacy and efficiency of tendon and ligament healing. Studies into the effects of the exogenous application of TGFbeta, IGF-I, PDGF and bFGF into the wound site singly and in combination have shown promise, significantly decreasing a number of parameters used to define the functional deficit of a healing tendon. Application of IGF-I has been shown to increase in the Achilles Functional Index and the breaking energy of injured rat tendon. TGFbeta and PDGF have been shown separately to increase the breaking energy of healing tendon. Finally, application of bFGF has been shown to promote cellular proliferation and collagen synthesis in vivo.
        Therefore, Trenbolone, by stimulating (b)FGF as well as IGF-1 - certainly would stimulate collagen synthesis. I don't know of anyone who claims trenbolone healed any injuries...but the evidence is here to suggest it.
        I'll write this up a bit more cleanly tomorrow, but I thought I'd present it to you guys tonight, before I got to bed.
        Gallery of Anthony Roberts
        Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post! Share on Facebook!Twit this!GoogleBookmarks!Reddit! StumbleUpon!SocialBookmarking!
