If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Injectable tren can But i have ran oral tren from 6 weeks on 2 pills and on this cycle im running 4 pills aday. I dont reccomend that high but its still not gona put weight on ya. It will cut you up tho
hey thanks bro good job by the way another ? then ill be done
i wanted to use Gp winstrol to cut up after my bulk cycle is complete do you think the tren is best or winstrol for fat loss and getting shredded i heard both can cut you up pretty nice?
for the most part, tren is a cutting drug. its also something that you want to stay away from if you're new to AAS. many side effects that can ruin your cycle and impact your organs. yes, you can gain muscle on tren, but you can really gain on any AAS if your diet is right. IMO, it isnt going to be the most effective though.
what to use? start with test. test should be the base of all cycles. test e or cyp at 350-500mg EW for 10-12 wks would be all you need to make some very serious gains. add in a low dose of an AI and follow it up with PCT, 2 wks after last injection. down the road, when you want to run winny, you will need to also use test as the base for that cycle too.
There are some people who dont like oral tren
This cycle im in i had oral tren and winny in my draw when it came time to add something lets just say the winny is still unopened and the oral tren is doing its job very nicely
can I use 250mcg a day oral tren to cut 10 lbs without a stack? don't want to bulk up, I am going to be on it for 2 weeks, 3 the most. will be doing cross training and HIIT cardio mostly
