Novice here looking for confirmation. Starting a Test C cycle in 6-8 weeks and gearing up now. What is the best pin size for glutes? I was thinking 23g but not sure if I need 1" or 1.5". I have done some reading and it is was not clear which is ideal. Thank you.
Pin Help
I use a 22 and 1.5 inch and no need to switch if you do a single draw. Make shore to draw back on the pin before you enter the bottle the same amount that your
going to draw out. Clear all air out of pin before you remove it from the bottle so not to waist any. Shits like gold... You will see. Give it 3 to 4 weeks and BOOOOM!!!
The shit hits and ITS ON!!!!Building my self for a better tomorrow.
What's your bf% like? I've always used 1in needles without a problem. You don't have to switch the pin out but the sharper it is the easier it goes in. All you have to do I pull down on the plunger once the oil is in the barrel to let some air in amd unscrew the old needle amd screw the new one right back in make sure to push the air out thoughOne decision determines your legacy
Pin size depends on 2 variables- your preference and the consistency of your gear. Heres what I do- to draw out of the viles I keep an 18g just for drawing , then I change the needle on my syringe I usually use a 25G pin as its big enough for most gear to flow through and it barely hurts at all. However once in a while I get some form of suspension that the gear isnt mocronized enough and that clogs the pin- so I go to 22G. anything lower is like a god dang harpoos and will be like midevil torture. Some oils are thicker and you may need to squeeze really hard but hey I think its better to inject slowly anyway.Originally posted by col4bin View PostNovice here looking for confirmation. Starting a Test C cycle in 6-8 weeks and gearing up now. What is the best pin size for glutes? I was thinking 23g but not sure if I need 1" or 1.5". I have done some reading and it is was not clear which is ideal. Thank you.The mind is the greatest weapon
Its so easy a child could do it- dont be afraid all you do is screw and unscrew- 22G hurts most people, If you are a beginner and not used to pinning, use 25G and get couple 18 to drawOriginally posted by col4bin View PostAlso, is it necessary to switch out the pin after drawing from the vial? How difficult is this to do?The mind is the greatest weapon
Seems like a lot of different ways to do this. I want to be sanitary and error on the side of safety. Do people reuse the syringe portion and just replace the needle? I was planning to get 25 pins with syringe which would cover me for a 12 week cycle. I though 23g would be a good middle ground but now I am not so sure.
I draw with a 22g and pin with a 25 or 23 depending on how thick the oil is. I Always use a new needle weather im drawing or pinning. To be on the safe side, go with 1.5 inch"I COUNT HIM BRAVER WHO OVERCOMES HIS OWN DESIRE THAN WHO CONQUERS HIS ENEMIES, FOR THE HARDEST VICTORY IS OVER SELF"
No youll be able to tell. Its kind of like putting water in one clear glass and oil in another and swirling them around. You can tell which one is thick and which one isntOriginally posted by col4bin View PostBeing new to this, I am not sure I will have the ability to gauge thickness of oil and gauge of pin.
Plus you will deff be able to tell the first time you draw. Since youre using test c, i would go with 25g to pin with at first. If it goes in smooth, stick with it. If you have troubles, try a 23g. Just have both on hand ready to go
I kno the test e/eq blend is thick as fuck but i didnt know that so i ordered 25g pins to use with it. Not a good idea. Took forever to pin with 25g. Had to switch to 23g and havent had a prob sinceLast edited by ALEX.18; 04-30-2013, 11:48 PM."I COUNT HIM BRAVER WHO OVERCOMES HIS OWN DESIRE THAN WHO CONQUERS HIS ENEMIES, FOR THE HARDEST VICTORY IS OVER SELF"
