If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
I guess this is where I learn something new. This would be only the second time I've used tren. Last cycle I did tren e. I didn't use anything extra then that I'm planning on not using this time. I'm open to any advice and woluld appreciate a reason why you would include it. Thanks again.
Ok so I just looked over your thread "first tren cycle" and I think you're going to tell me to add dostinex. If that's the case, I don't feel its necessary for me to add it. I could be wrong and a lot of people might think that I should add it. My only humble defense is that I didn't experience any sides from tren, other than rediculous but manageable heartburn. Again I could be wrong, but I've liked your suggestions so I'm alwas open to listen to advise, even if I respectfully disagree......others are welcome to chime in on this. Maybe tell us their own experiences with tren, things that worked, things they would change, etc. Thanks again
I can't argue with that logic. Better safe, and have it just incase, then sorry and suffer the adverse effects. I'm gonna go ahead and add it to my cart, and not use it unless I see something different and need to use it. At that point ill probably go with the doasge and frequency that you have on your thread. I've had letro on hand every cycle and never had to use it. But id never want to be without it. Can't hurt just having the "just in case" on hand. Great advice. Thanks again. I think ill start my cycle before what you plan to start yours, so ill let you know how its going. Still not set in stone when ill start mine. But best of luck with yours. Your stack looss great.
Awesome feed back. With the test I was thinking of adding another 350 a week of test e. I'm good with the winnie at 40 for now but ill give 50 a chance to see if it makes that much more of a difference. The only reason I'm a little hesistant is I've never done t3 before so I'm not too sure how to dose it....I would like to do clen for the entire 10weeks, how would you suggest adding in the t3. I plan on using benadryl every third week to keep my receptors clean.
sigpic
NapsGear.Net - The Largest and Most Trusted!
ive also acquired me some dostinex, incase i have any problems with the tren since my last deca cycle gave me some prolactin issuses. i also got adex and then letro jus to have on hand. any1 who uses aas should always have a few packs of letro on hand. im planning on .5 e3d on the dostinex. u?
I just added 25 tabs of sun pharma cabgolin dostinex to my cart. As of right now I don't plan on using it unless I need it. I didn't have any issues with tren last time, and I rather not take something I don't need. If I notice any sides then ill probably go with .25mg e3d. I liked alexs reasoning on this. If I'm wrong in my thinking either in my dosing or not taking it from the start then I'm open to good reasoning from everyone.
Exavtly wat i got. But alex sed to run .25 incase i need to go up then i can so ur dose is good. Last time i ran caber i was taking a lot but it was liqiud and i think it was bunk or underdosed
sigpic
