Test only cycle
  • Test only cycle
    The more research I do, the more confused I get. For a first cycle, I was set on a Test E or Cyp with D-Bol for 10 weeks. I want to keep it simple to see how I react. Seems that some
    schools of thought suggest just running test alone. What do you think? What is the minimum # of weeks to run test yet still be effective.
    Most say 8-12 but at that amount of time I think you are cutting it a little short. Personally, I cycle for 16-20 wks but of course on different compounds.
      Thanks. My problem is I have a week where I will be out of town in July and unable to pin myself since I will be traveling via plane and unable to lift for that week. I wonder if I should just wait until the fall when I have no trips planned. I will be traveling out if the country in August and September too.
        Well if you're using compounds with enanthate or cypionate esters they las 8-12 days in the body so you can just dose before you fly unlesss you're going to be gone longer than that.
          Oh, ok. If I was dosing 2x250mg/week, could
          I change to 1 500 mg for the one week I am gone?
            Yes, but the location of injection would also more than likely have to be quad or glute unless you pin on each delt or tri. If you're going to be walking a lot I don't recommend the quads because they tend to get a little sore.
              Thanks. I plan to do glutes. Was thinking 23g 1". Sound right?
                Yeah sounds right Good luck bro.
