Still undecided
  • Still undecided
    Would you go with 1 ml adro mix eod
    Or
    200mg Test P 100 mg Tren EOD
    Price is virtually the same for me. Goal lean muscle gain some BF loss. I am really torn.
    You'll get those goals from using either ones... from using any steroid for that matter... your diet will make it what you want it to be..
    Ain't no use in lookin' down
    Ain't no use in lookin' back
    Ain't no use in feelin' blue
      I know on diet, I guess I am seeing what people think is more fun to be on. I like the edge I get on juice, I go harder feel better and want to fuck every second. I had a hard recovery the last time I used Mast and nothing really using tren alone.
        I'd personally go for the Prop/tren instead of endro...even tho the only thing that changes is the masteron and dosing you want.
          1 ml andromix EOD will only give you 50mg of test EOD. thats pretty low. i would personally suggest going with 100mg test prop EOD or more
            Andromix is great! Has a very nice blend that compliment each other very nicely.
            If the max you can go with is 1ml EOD that will give you roughly 200mg/week of Prop,Tren,Mast. That's low dosage to really get good results from it. I would say minimum 2ML EOD or keep the 1ml of Andromix and add in Test Prop EOD with it
            If it absolutely has to be one or the other and not add anything then I would go with Test 200mg/Tren 100mg EOD. That will give you roughly 800mg/week of Prop and 400mg/week of Tren
            You will be missing out on the Mast which is a mild anabolic - will harden you up and work as an anti-estrogen
            I'd go with that option for sure if you can't alter the first one. The real magic comes with the Tren.
              I have extensive experience with Andromix / Cut Stack. I would not run it alone... I would suggest running Sust, or Test E, or as Sam suggested, additional Test P along with the Andromix / Cut Stack. You could even go with Dbol as a compliment. I have run it with 400 mg of EQ per week and gotten fantastic results at 1 ml EOD.
                So say I am trying to stay around the $300 mark. Thats leaves me running andro 2 ml eod for about 8 weeks, Or 200mg test p 100mg tren from fina for 10 weeks or 1 ml andro plus an extra 100 mg testp EOD for 10 weeks. Whats the consensus.
                  let me back up just a little here. have you used prop before and have you dont EOD or ED injects before? how many cycles have you done so far?
                    have ran TEST E only twice, Test C only, Test P and Npp EOD, Winny only ED, Test P mast EOD, Tren 4 times or more ED and EOD but only by itself, then Clen and T3.
                      ok sounds good bro. i was concerned for you if you were newer and hadnt run fast esters before. sounds like you'll do just fine haha
                        ED and EOD is no joke but I really prefer it. I think the bloat is a ton less and something mental about poking everyday.
                          Sam out of all the combos what would you do.
                          200mg test p 100 tren A EOD 10 weeks
                          2 ml Andro 8 weeks
                          1 ml Andro + 100 test p EOD
                          Or screw it 200mg testp EOD save some money maybe throw in some clen or t3.
                          I am looking for some help to get 5 lbs muscle and 5 lbs fat loss , so I dont need any big guns. I will run HCG with everything I swear by it for recovery.
