Gp test cyp?
  • Gp test cyp?
    I received my gp test cyp today. It's cloudy and jelly like. Is this normal I have used several other brands and I have never seen this before.
    It isnt uncommon with the cyp ester. It doesnt stay in solution very well when you get above 200mg/ml unless you use EO or some other carrier. It is probably a bit overdosed or it got cold in transit to you. Just heat up some water in the microwave for a couple of minutes, sit it in there, and swirl it around. It should go back into solution no problem.
      Correcto! Nothing wrong with it. Just use the hot water method mentioned
