Thoughts on my Karachis?
Karachis S250?
Originally posted by Mr Ontario View PostThoughts on my Karachis?if you are new to the board, please take a minute to read the rules...CLICK HERE
Look closer
Also they are made by Organon and come from Pakistan
Originally posted by sam1976 View Posti have only even seen a handful of these in my life, so i won't be much help, but i'm surprised to see the various amounts of oil in each one. is that common with them?Ontario Yours To discover
I have seen plenty of these. I even have some now. The labels on yours look good but sam is right about the different amounts in each. They should all be exactly 1 ml.
Ok ive just looked at the pics more closely. They are all different cos some of the oil is in the lids. Shake em up so all the oil falls to the bottom then see if they are all the same. I think thats all that is.
My only issue with these is the length of the neck. They are a different heights. This isnt usual for organon that im aware. Ive had 50 bottles at one time and every amp was the same size. Other than that they look ok. If thay are a copy then they are a very good copy.
Look at the word proprionate and phenylproprionate. Is the letter "i" capitalized or lower case with a dot above. I mean does it say proprionate or proprIonate? This is apparently a common fake. The genuine ones are all "i"
Karachi
Most counterfeits are very good these days that why we pay attention to details. If I get the chance I scan both amps +300. Look at the comparison of an old amp (left) with a chinese counterfeit.
Your amps have different contents visible but mostly some sticks in the neck. Shake it out and then look again to see if they are evenly filled. Also look to the printing of the expiry date. On first glance they look good if the content is 1 ml.
those SUSTANONs are deffinitly real...
I get them directly from Pakistan, and those are good to go...
every amp have THE SAME AMOUND OF OIL, it is just hiding in the neck...
and lettering is as good as that can be...is it pakisatan, bro...and spelling is right too, for exemple it sais propionate, unlike on many fakes proplonate.
I have batch 0146 (stock of ot), and em using it for month or two, in this time I made hormone tests and all are high as they should be!
good morning from slovenia
