Norma real or fake?
that number print should be on the yellow hologram paper. The white portion of the label usually doesnt extend up that high. Put it under a UV light and check for the hologram. Probably not there. All the legit ones that i've had, the yellow hologram paper has extended out past perforation line. I also dont see the watermark on the sticker vial. it is usually somewhat visible in most pics i see.
snatched a real box and sticker from a member here so you can see what im talking about with the yellow hologram paper.
Real and fake nandrolone decanoate by norma
Today we learn like one real Nandrolone Decanoate Vials of wrong or counterfeit ones can recognise. We have here some pictures where to her on the left the Orginal and on the right the replica can see.
If we come first to the packaging. One can recognise by the packaging easily the pressure differences. The blue tone with the Replica version goes over bright in a brighter tone. Furthermore the embroiderer background is white and not white-yellow. Last we can examine black pressure on top on the packet which appears with the Replica clearly more sharply. This should wake the appearance which concerns it real version.NO ONE SHOULD DIE IN CHAINS!!!
Now we come to the content. If one an original packaging opens the description is under the Vial and not like with the replica about the Vial.
Last we come to the Vial ourselves. With the demolition cap the differences start. The original demolition cap has a form of a circle, while the replica has a form of a circle with horizontal lineNO ONE SHOULD DIE IN CHAINS!!!
If we come last to the label and to the security signs. One has the original label a sort of hologramme cover which with the naked eye hardly recognises. Behind the label a logo which the Bulgarian forgers have also installed with was branded in the glass. We can ascertain very strongly on the label whether it concerns a forgery. Also one can approximately recognise by the colour of the oil what is wrong. The real version has yellow-murky oil, meanwhile with the replica white-murky oil was used.NO ONE SHOULD DIE IN CHAINS!!!
