Originally posted by Dan Duchaine
View Post
Deca problem!!
then he will need dostinex 0,5mgs twice week, and this will also increase a much better sex drive, now i dont know if he runs test or not but test shall always be a base at least in TRT doseage. and if you need an anti e try aromasin or arimidex, letro is over kill.Originally posted by big1 View PostBut what if Cruz problem is prolactine based? Then what?
Just thought I'll re-word it??Originally posted by mbig245 View PostKindly disagree, If his estrogen is elevated more than he needs then letro would work.(Because, if the estrogen is to high it will ALSO kill libido!!) I'll take a tab and its good for 2 days or so. I'm not saying to use it as a preventive drug but only to get rid of the symptoms quick. Once you get your estrogen under control then go to the Arimidex .5 eod or if you need more do it .5 ed. The only thing useless would be nolvadex..( Because, Nolva will from what I've gathered, cause a prolactine issue when used with Deca,and Tren!!) I know this because a buddy of mine was using DECA and he got some nolva, started taking it, and Boom!! His nipples were getting wet!!!
Dan, won't you post up a avi. picture ???
i have been thinking what to say here. really, the only way to know whats going on is to have blood work done. i've found that even with a good dose of test, sometimes deca still messes with my sex drive a little. it could be prolac, it could be too much or too little estrogen.
maybe i missed it but have you been using an anti e at this time?if you are new to the board, please take a minute to read the rules...CLICK HERE
