Deca problem!!
  • Deca problem!!
    Okay
    So coming in to the final part of my cycle (4 weeks left) 2 left of Deca and my sex drive is starting to fade, Im assuming this is a response to the Deca.......... is there anything I can do to boost it back again?
    take some dostinex and shoot some hcg about 500iu twice week, this work for me.
      What I've done in the past is, Take some letro and a viagra. You'll have a love - hate relationship with deca!! lolol
        so you use deca without testo,or just not enough testo?deca without test is a killer,maybe you can't go wrong with some proviron...
          Do not use deca. Use Boldenone or primo instead
          Question is, is your problem made by high estrogen or hi prolactine.
            Cheers for the feedback guys
              Just ordered the letro and got a shed load of Viagra here, Think ill skip Deca next time
                deca is nice if you know how to control the side effects, watch out letro may fuck you up iven more its tottaly usless for your problem.
                  Kindly disagree, If his estrogen is elevated more than he needs then letro would work.(Because, if the estrogen is to high it will ALSO kill libido!!) I'll take a tab and its good for 2 days or so. I'm not saying to use it as a preventive drug but only to get rid of the symptoms quick. Once you get your estrogen under control then go to the Arimidex .5 eod or if you need more do it .5 ed. The only thing useless would be nolvadex..( Because, Nolva will from what I've gathered, cause a prolactine issue when used with Deca,and Tren!!) I know this because a buddy of mine was using DECA and he got some nolva, started taking it, and Boom!! His nipples were getting wet!!!
                  Dan, won't you post up a avi. picture ???
                  mbig245
                  Last edited by mbig245; 10-10-2011, 09:28 PM. Reason: To explain in simple terms!!
                    whell estrogen is not the problem here, and im my opinion letro is over kill to control estro, exept if you do a contest letro will dry you out totally, but also kill your libido.
                      Why does the new guys always critique?? Still haven't heard your expert opinion on what you would recommend.
                        lool..... i feel the testosterone in this room.. MEnErGy
                          MBIGS in da house CUZ!!! hahahaha
                            hahahaha I know no advice just critique, The letro has worked before but im getting the letro to reverse my Gyno as i always grow a nice pair of moobs if i even look at an amp.
                            Im going to up the adex I think
                              its not a critique, but if the problem is libido you will try to avoid letro since it will kill your libido.
                              i recomend aromasin and nolva mix this will boost the libido, ad some hcg and your gtg, but still dont see a reson to use letro here.
