oral vs injected AS
  • oral vs injected AS
    I was wondering whether anyone had tableaus with numbers/percentages comparing both oral and injected AS, as well as their efficiency? I couldn't find any post with comparisons pros/cons etc...
    Ain't no use in lookin' down
    Ain't no use in lookin' back
    Ain't no use in feelin' blue
    the side effects from orals is much worse. you can run injectables at higher doses for longer periods of time. basically, you can get better results from an injectable. the base of your cycles should be testosterone.
      Thanks Sam, much appreciated.
        Orals are basically accessories to a cycle. Test as a base. Dbol and drol are typically used as a jump start. They will add weight and strength at a more rapid rate but they will be more harsh on the liver and posibly produces side effects quicker. The gains can be harder to keep because of how rapid they come on. But they have their place.
        In the end diet determines the type of gains. You can cut on dbol and drol but you really have to have your diet in check. Anavar is pretty mild on liver but you don't get the same type of gains.
        Overall injectables are safer and better in the long run.
          xamo I think if u do a search for "oral only" cycles u will find pros + cons -(mostly cons).
          if ur about bulk + long term benefits inject is best but I also believe their has been some success with short term (3weeks) oral only cycles - gains about 5lbs.
          depending upon what oral+dose u take 3 weeks is said to minimize if not eliminate the Naty Test Shut Down?
