Gp Test Enath 250
  • Gp Test Enath 250
    Thinking of running this with Gp deca 250 but I have not seen 1 effective log of the test not 1. From what I see is that its severely underdosed. Any links or experience to prove otherwise?
    it was tested to check it was 250mg/ml and it was 306mg\ml= http://juicedmuscle.com/showthread.p...Test-Enanthate many people have used it/ are useing it with good results if you look around here you will see people talking about it, also what do you see to make you think it is underdosed?
      Crack kills Trust in there goods
        MODERN DAY GUNSLINGER
          Just reviews from many forums. Some are even sponsored by legit GP carriers, so its hard to ignore that. I just dont want to pump myself up then realize around week 5-6 that im pumping myself up full of olive oil.
            is this going through?
              I just quoted you Jimmy I dont know why it didnt go through. To answer your question I have came across several logs in a few forums with ZERO results. Most of them called it bunk the more optimistic ones declared it underdosed. Some of the forums were actually sponsored by legit GP carriers. So its hard to ignore that. I just cant put myself through a cycle and find out week 7 that im not a "responder". Thats where im coming from. you know I read a lot of logs and never came across one with postive results from GP Test Enath 250. I want to be proven wrong, believe me.
                If you have that lot, cool; however, I haven't seen any test results for newer lots.
                  Anywho, I have seen bloodwork posted on GP TE 250 and Total test was 1500. And I saw another blood work, which had similar results.
                    I can tell u from experience I'm finishing up right now with it gp test e and one thing I can tell u is its far from underdosed its gtg been useing it for 8weeks now if people are saying different it wasn't from are sponsor or it wasn't gp
                      OP your entering this topic with negative view. the reason you might have not found anything on it, is because its so bread and butter that people didnt really talk about it. Ive used test e which i got from my dealer then mid cycle switch to GP. i will tell u honestly, there is nothing underdosed about it, i got real sides. Acne, oil skin, hair started shedding a bit, my gains continued to come. Personally, you cant beat 306mg tested per cc. you just cant
                        GP products are top notch. No complaints at all. Many many positive reviews.
