HI does anyone know the half life of this ,and has anyone ran it ,any knowledge on it, as seacrhed the web and cant seem to find any logs, apart from people trying to get info themselves
Gp mhn
Pharmaceutical name: Methylhydroxynandrolone
Pack: 50 tablets (5mg/tab)
GP MHN is an oral product containing 5mg of the hormone Methylhydroxynandrolone per tablet. Methylhydroxynandrolone is a Nandrolone derivative however the 4-OH group added inhibits a conversion to DHT (dihydrotestosterone) or DHN (dihydronandrolone) making this a mildly androgenic and highly anabolic compound. There is also no conversion to estrogen or progesterone. This makes the compound favorable for those in "cutting" cycles.
Users of this product would typically experience increases in lean mass as well as moderate strength gains. Increased nitrogen retention, making the body a more anabolic environment. Central Nervous System (CNS) stimulation, not in a jittery ephedrine type feeling but you should be able to sleep less and still feel refreshed upon waking. Less time is needed for recovery between sets and workouts. There should be no decrease in sex drive, and should help with joint pain. Increases in the ability to lose fat while increasing vascularity. The side effects of this compound have shown to be very mild with few side effects. But all steroid hormones may cause acne, accelerated male pattern baldness, gynecomastia, testicle shrinkage, increased facial and body hair in men. As well as voice deepening and clitoral enlargement in females. However, this product has typically shown to be on the low end of such side effects.
Dosing should be 10-20mg per day (2-4 tablets) based on bodyweight and/or experience of individual. Always start with a lower dose and increase slowly every 5 days as needed. Do not use for longer then 6-8 weeks, followed by a full PCT protocol.
MOHN
(Methylhydroxynandrolone)
MOHN Description:
MOHN, a.k.a. Methylhydroxynandrolone, is an oral derivative of the anabolic steroid nandrolone which was clinically developed for the treatment of severe wasting disorders such as advanced HIV and refractory anemias. The primary difference between the two, and the difference on which the others hinge, is the addition of the 4-hydroxyl group. This alteration both increases MOHNs potency and causes it to act more like the steroid Trenbolone.
Additionally, MOHN has been c-17alpha alkylated, a modification that permits the drug to pass through the liver and into the bloodstream without being deactivated, thereby making it effective for oral administration. The resulting compound is a potent oral steroid thats very similar to a stronger Anavar (Oxandrolone) a comprehensive DHT-derived, oral, anabolic steroid that provides you with some of everything (muscle, strength, definition, endurance, fat loss, etc.). As if those attributes werent remarkable enough, MOHN does all this without aromatizing (converting testosterone to estrogen), making a favorite among competitive athletes.
MOHN Form:
MOHN comes in tablet form for oral administration, and is generally found in 5 mg of steroid per tablet. Neither MOHN, nor any of its generic versions are still being commercially manufactured as prescription medications.
MOHN Indications/Purpose:
Although this steroid is a nandrolone derivative, it acts quite differently from its chemical parent. While nandrolone is a relatively moderate steroid, MOHN is a very potent one. As mentioned above, its properties are multi-faceted and vastly similar to the more comprehensive natures of Trenbolone and Anavar.
Based on its chemical structure (and unlike such steroids as Halotestin with its anabolic/androgenic ratio of 1900/850), MOHN on paper potency translates well into real world results, central to which is increased nitrogen retention for the production of solid muscle development on par with that of the steroid Trenbolone which a greater lean muscle generator than Anavar. MOHN users also boast reduced body fat, much like the clinically proven overall body fat loss acceleration, muscle hardening, and vascularity enhancing properties of Anavar. These benefits alone make MOHN a formidable androgen, but it also encompasses other traditional steroid properties like: increased red blood cell (RBC) production; improved endurance during exercise via better lactic acid clearing; enhanced oxygen and nutrient delivery to working muscles for greater endurance; better muscle glycogen restoration after exercise for faster recovery and; the inhibition of catabolism (muscle destruction).
MOHN is a very adaptable compound that can be easily incorporated into all types of cycles, during both your bulking and cutting phases of training. When used within mass building cycles its usually stacked with testosterone and/or Deca-Durabolin. In cutting cycles its often combined with short-ester injectable anabolic steroids such as Testosterone Propionate, Trenbolone and Boldenone Acetate, but there is virtually no limit to its applications.
Due to a high milligram for milligram potency, the typical effective daily dosage is comparatively lower than most orals. For example, recommended dosages for Anavar, Winstrol and Turinabol are all within the 50-100 mg/day range. Even the legendary mass building Dianabols average dosage of 20-40 mg, is considered high with regard to MOHNs recommended 10-30 mg per day for 6-8 weeks.
MOHN Side Effects:
Since its a progestin (as are all nandrolones), it stimulates the progesterone receptor, as well as progesterone itself which opens the door for some unwanted side effects. As with any form of anabolic steroids, it can possibly cause side effects which fall into two primary categories, estrogenic and androgenic.
MOHNs very low aromatization means you can expect to be virtually free from estrogenic side effects (those due to increases in estrogen estradiol, prolactin, progesterone or progestin) which generally include increased water retention, body fat gain, and gynecomastia (actually due to an imbalance in the testosterone to estrogen ratio).
Androgenic side effects, those having to do with male sexual characteristics, occur due to elevated testosterone levels which are likely to produce oily skin, acne, body/facial hair growth, and testicular atrophy (temporary reduction in the size of your testicles). Androgen drug use of any kind is also known to accelerate balding, but only in men with a genetic predisposition for hair loss. In other words, if youre losing or going to lose your hair then testosterone supplementation can speed up the process, but it is never the primary cause of hair loss.
Synthetic testosterone and several other steroids, including nandrolones will shut down natural production altogether. A mere 100 mgs per week of either of these takes about 5-6 weeks to cause this shut down, 250-500 mgs shuts you down by the second week, and it takes roughly a month to return those testosterone levels to baseline. MOHN may not be androgenic enough to promote shut down, but it will definitely suppress natural testosterone production.
MOHN Chemical Composition
4-Hydroxy-17alpha-methyl-hydroxyestra-4-ene-3-one
Manufacturer: Multiple
Effective Dose (Men): 10-30 mg/day
Effective Dose (Women): Not Recommended
Half-Life: Approx. 12 Hours
Detection Time: Unknown
Anabolic/Androgenic Ratio: 1304/281
Read more: http://www.steroid.com/MOHN.php#ixzz1Lm7SLqa7
