Winstrol(1st time) Need advice
  • Winstrol(1st time) Need advice
    Can somebody give the whole breakdown of a winstrol cycle? What dosage? Needle size? How often? What should I take with it for the liver, if I should? Anything else I should take for protection?
    GP Stan 10 by Geneza Pharmaceuticals is an oral steroid which contains 10mgs of the hormone stanozolol.
    This is the same substance that is suspended in water in GP Stan 50 inj.. The oral preparation of this substance allows bodybuilders to avoid the discomfort of everyday injections which are the normally the protocol with the injectable version. Due to the fact that taking this product with food can cause absorbtion problems, it is recommended that one take GP Stan 10 on an empty stomach for best results. Some bodybuilders also choose to split up their dosage of GP Stan 10 throughout the day in an effort to keep blood levels as consistent as possible.
    Winstrol , as it is most popular referred to, is one of the most popular steroids in use today. This drug has very low androgenic properties and very high anabolic properties. GP Stan 10 does not have the ability to aromatize and therefore will not cause any water bloat. This has made this steroid very popular with bodybuilders in the cutting phase of their training.
    Users of winstrol often report good gains in strength, vascularity, and muscle tone. People often report very intense muscle "pumps" during workouts when using this compound. This can be attributed to the dynamic protein synthesis and nitrogen retention brought about by the use of this steroid. Some studies have also shown that winstrol has estrogen and progesterone blocking abilities, making it a good choice to use with other steroids such as Testosterone , Deca or Trenbolone.
    Winstrol also does a very good job of reducing the amount of SHBG in the body, thus allowing other steroids to be much more abundant in their free state in the body. Due to this fact, GP Stan 10 makes a great addition to all cycles. Winstrol is a C17-alpha alkylated compound, and therefore can be toxic to the liver over time. Because of this, it is recommended that bodybuilders using this compound try to keep dosage in a reasonable range and limit cycle duration to 10wks. There are also several liver protectants and detoxifiers available which should be considered when doing a cycle of this steroid.
    Due to its low androgenic activity, GP Stan 10 is a very good choice for women bodybuilders. Males typically use GP Stan 10 in dosages of 40-100mgs a day for a period of 6-8 weeks. 5-10mg a day for a period of 4-6 weeks is the normal dosage range for women.
      Thanks man. I need some info on the injectables. Injectable winstrol is within easy access opposed to the orals.
        Hopefully i can get ahold of some orals soon
          Winstrol injectable is a product that will help bring out your vascularity and muscle hardness as well as improve your strength.....a 25g 1 inch pin should be fine for injecting you should plan on 50mg Every day up to 100mg every day for best results.....Some users of Winny report that it seems to "dry" out their joints while on a Winstrol cycle so as a precaution some users will stack it with Deca to help keep the joints lubed and pain free
            i appreciate the info limo it really was helpful
