getting ready to start a suspension cycle, i also got b12 to go with the injects. any advise.
suspension
best of luck. what kind of dose are you running? have you run susp before? how about TNE? if so, how would you compare the two?if you are new to the board, please take a minute to read the rules...CLICK HERE
susp is usually injected every day. because there is no ester, it passes through your system quickly. some guys run it 2 to 3 times a day. i've heard of people using b-12 at a 1 to 1 ratioOriginally posted by unionbrother View PostI have never used suspension before so I’m a little nervous, was thinking of running 1cc/100 mg every 3-days.
I have used both ethanate and Cypionate in the past.if you are new to the board, please take a minute to read the rules...CLICK HERE
ahhh, i didnt see your post before i commented. i agree, ED injectsOriginally posted by Newgoal300 View PostSuspension needs to be taken everyday to keep stable blood levels, 1ml of b12 per ml of suspension has worked for me. Expect dramatic and immediate effects. Suspension can be a great mass builder if used correctly! Suspension, prop, tren a and eq are my favorite stack!if you are new to the board, please take a minute to read the rules...CLICK HERE
are you using the water based or oil based?if you are new to the board, please take a minute to read the rules...CLICK HERE
The 13th will be 4-weeks of suspension at 100mg every day. I should be looking at around a 20 pound increase in body weight.
I would never recommend anyone using this as a base test for 10 weeks. The injection sites are a mother fucker.
I’ve started 800mg per week of test E this week. So I’m done with the suspension after this week.
some water but nothing extremely bad.
Strength increase was pretty good. Comparable to IH Anadrol.
