veteran Competitor new to AAS
  • veteran Competitor new to AAS
    Hey all. looking for advice.
    Specs-55 years old. 5 10, 195 stage weight. 210 off season. Been competing since 1988 all Natural.
    2016 Ran my very first cycle. Test cyp 500mgs/250x 2 shots weekly. did 8 weeks. Gained 8 lean lbs of muscle.
    2nd cycle end of 2016. Test cyp again at 500 weekly for 10 weeks with winstrol last 4 weeks. Did bloodwork before and after with full pct. total gained after both cycles about 12 lbs of lean tissue.
    fast forward to today. trained hard all winter and looking to get on cycle again. I live and love the bodybuilding lifestyle and theres is no offseason/drinking alcohol/drugs for me. been that way all my life.
    I have a big show in May and july. heres my challenge. peaking for 2 big shows. I want to do the Beginner cut from Naps gear (8 weeks cycle of test prop@300mg weekly, 40 mg of stanzolol6 weeks and Anastrozole .5 daily)
    so If I did this 8 weeks before my May 20th show, what suggestions would you reccommend for my big show 6 weeks later july 1st?
    questions
    * My first cycle was test cyp and I held water. cut the test cyp out 2 weeks before last show in 2016 and it helped lean me out. also i used NO A.I. during both cycles. can I use the test prop right up until the show?
    * what should I do right after my first show this year (may 20th) to peak again for my second show 6 weeks away July 1st?
    Thanks to anyone who helps. Im such a newbie at this. sorry if i left out any pertinent info. please ask if I did and Ill answer.
    **want to add im open to just focusing on the july show if more "realistic". I was thinking using test cyp with masteron/proiviron for a longer run. Need some input from veterans. I enjoy the stage as it keeps my azz in high gear BUT "common" sense is important when dealing with AAS. Thank you
    masterblaster
    Hey Brother,
    Two shows, 6 weeks apart is going to be tough to peak at them both. The thing is, only you now how you respond to your training and diet. The only thing I would say is you may be better off concentrating on one show, but again only you know if you can pull it off. I would also say add some Clenbuterol to your cut, just make sure you get some Benadryl to clean your receptors if you want to use it continues and not do the two weeks on two weeks off. This may help you hit that second show.
    Chat Box Talk And Rules
