Dianabol also known as methandrostenolone and other trade names, depending on the maker. Dball is a much stronger hormone then testosterone, it can be taken orally a couple times a day. They also have a liquid dball 30ml 25 mg per cc but will vary depending on maker. Dball is still high in demand, it is usually the first cycle a user does. It's kinda cheap but very powerful drug and mass, due to much water retention. It is also good for those not wanting to take shots.
Most first timers will use dball by it self and notice that once stopped all is lost. However experience users use other oil steroid in conjuction. Usually the first four weeks the dball is use to boost gains quickly, while awaiting the oils to kick in. Using 30mg-50mg per days usually yields 15 pounds. Duration of use is usually four weeks and discountinued and by then the oils is kicking in continuing to solidify gains.
SIDE EFFECTS
Enzymes in the male body will turn dball into a strong estrogen hormone, that will cause the following problems, water retention, acne,bitch tits,if anti estrogen is not used. You can lump up and may require surgery. But as I said they can be avoided or treated with ancillary meds, arimidex,aromasin and letrozole
SIDE EFFECTS
