Hi guys my dad wants to try a mild cycle with me this month coming up but he has had prostate health issues in the past like trouble pissing. How can he keep DHT low and what steroids can be used to give him nice results safely?????? I was thinking test cyp only at 1st but he might be able to use a low dose deca as well. If he can keep DHT low he can raise the roof a little on the doses or cycle longer . thanks for anything u guys think. Note ( his doctor is watching everything)
How to reduce DHT for prostate health also what steroids can be used to afect the pro
None of this may come as news to many of you, but I bet that very few of you know that DHT can actually be used to treat BPH!! How can it do that? It basically does this by replacing the testosterone in the body, which then has the effect of reducing the amount of estrogen in the body.
"DHT can actually be used to treat benign
prostate hypertrophy (BPH)!"
As I started to explain before, DHT is a strong androgen that will signal the pituitary to decrease the production of gonadotropins. The decrease in gonadotropins will then cause less testosterone to be produced which will in turn cause the estrogen levels to drop. The resulting change in the hormonal milieu (high DHT, low estrogen) then apparently results in a regression of BPH. The clinical application of this theory is discussed in US patent 5,648,350 Dihydrotestosterone for use in androgenotherapy.
