Test E, Tren E, Drostanolone E (Masteron) cycle help, please
  • #16
    Thanks alot everyone. There is just one more question, when taking the aromasin and the caber on cycle and post cycle, do i take them with food or on empty stomach??
    • #17
      I take it before bed if i forget I take it when I wake up and resume schedule
      • #18
        ok, just to make sure, using only the aromasin for PCT @ 25mg ED should be enough??
        • #19
          No not enough will reply more tomorrow sleep time
          • #20
            I use hcg 250iu eod for 2 weeks, 20mg nolva ed for 4 weeks,
            25mg aromasin ed for 6 weeks.
            • #21
              I will be using a mix containing Test E, Tren E and masteron E which has 100mg of each per 1mL. what's the best dosing for this mix?? I plan on using Aromasin on cycle, but don't know the proper dosage. As for the PCT, I will also use Aromasin, but i need to know the proper dosage, and when to start after my last pin? I will also be including caber on cycle @ .25mg E4D is this right or wrong??
              Are you sure your right about this mix?? Sounds more like it's an acetate mix Test Prop, Tren A and Masteron A? Never heard of a mix like you described.
              sigpic
              • #22
                I've seen all kinds of mixes lol saw one that was called 'winter blast' 100eq 50trenE and 100 testE per ml u can make your own mix I don't trust any mixes and some multi estered test is just prop and Enanthate mixed usually
