I will be using a mix containing Test E, Tren E and masteron E which has 100mg of each per 1mL. what's the best dosing for this mix?? I plan on using Aromasin on cycle, but don't know the proper dosage. As for the PCT, I will also use Aromasin, but i need to know the proper dosage, and when to start after my last pin? I will also be including caber on cycle @ .25mg E4D is this right or wrong??
Test E, Tren E, Drostanolone E (Masteron) cycle help, please
whell with this dosage ml you should shoot 1ml eod, i love aromasin and this is the only ai i use both on cycle and pct. you should be gtg with 12.5mg eod and if you need more go 12.5mg ed as for pct start the aromasin 7-8 days after last injection and go 25mg ed for 4-6 weeks and ad some hcg and 10mg nolvadex for 4 weeks too. for caber i use 0.25mg twice week and works for me
you may not need the nolvadex but i use it at 10mg the first 4 weeks, some time 10mg nolva with the aromasin take the egde if im on heavy test dose.
This mix has the enanthate ester, shouldn't it be injected less frequently? like for example 1.5mL E4D ? so it will be 150mg of each (tren, test, mast). As for pct, isn't 8 days after last injection to short for the compounds to clear the body? I know that any enanthate ester should take about 2 weeks to clear from the body, then start the pct. For the caber when do i stop using it?
Enanthate half life is 5-7 days other half another 5-7 days. staying in high dose for while takes while to clear out it compounds in each other I always did 3 weeks or so never worked always felt horrible pct sucks good luck ide run the caber through atleast half of pct just because tren is gone doesn't mean u its not lingering metabolites of enanthates still taper it into pct as well
Originally posted by blackshark50 View Postso with the mix I have, it's best to inject 1mL EOD and 12.5mg aromasin with cycle EOD + caber @ .25mg E4D, and start pct 8 days after last injection with 25mg aromasin ED for 4 weeks, right??
You can also go for 3times EW, run the aromasin at least 4 weeks in pct
And like pesto said run the caber in the pct too
Like 2-3 weeks then u gtg. When i pct after a tren cycle i also ad some hcg like 250iu 3 times week first 2 weeks of pct, you can do without but then maybe run the aroma 6 weeks.Last edited by Italo; 08-17-2015, 10:53 PM.
Originally posted by blackshark50 View PostItalo said in his post to wait 7-8 days after my last injection then start the PCT, and you are saying you'l wait 14-20 days after last injection then start PCT, I'm confused here
Originally posted by Pestosterone View Post3x week is M W F for me
- - - Updated - - -
Ide wait 14-20 days for pct to start btw
ps every body is different and react different find out what best for your and listen to your body
