Ok so I'm on my second week of hcg I bought of jintani labs already reconstituted and ready to use. And I have read that it helps keep all gains and works as pct alone well it's going great I have started slacking on my diet not eating as much and not eating right and I have not lost a pound, well lost water weight but nothing major feeling good and still poppin boners. Loving hcg will skip clomid and keep it just in case so far so good gentlemen.
HCG so far so good
this is by far not my "specialty" but i would advise not using hcg for pct... use it all the way up to a few days before you start your SERM. Hopefully someone with a little more reputation will jump in and back me up.
I myself am using hcg at 500mg/wk split into two doses during cycle but will not be using into pct
So then I should follow up with clomid after? Ok so I want you guys to read this and give me your opinion is this true or false? Cuz I I'm translating it is that you can use it as pct but not trying to argue just want to know if my reference is bad and get some honest opinions, I have clomid and will use it if need be.
HCG is often used in combination with anabolic/androgenic steroids during or after treatment. As mentioned, oral and injectable steroids cause a negative feedback after a certain level and duration of usage. A signal is sent to the hypothalamohypophysial testicular axis since the steroids give the hypothalamus an incorrect signal. The hypothalamus, in turn, signals the hypophysis to reduce or stop the production of FSH (follicle stimulating hormone) and of LH. Thus, the testosterone production decreases since the testosterone-producing Leydig's cells in the testes, due to decreased LH, are no longer sufficiently stimulated. Since the body usually needs a certain amount of time to get its testosterone production going again, the athlete, after discontinuing steroid compounds, experiences a difficult transition phase which often goes hand in hand with a considerable loss in both strength and muscle mass. Administering HCG directly after steroid treatment helps to reduce this condition because HCG increases the testosterone production in the testes very quickly and reliably. In the event of testicular atrophy caused by megadoses and very long periods of usage, HCG also helps to quickly bring the testes back to their original condition (size). Since occasional injections of HCG during steroid intake can avoid a testicular atrophy, many athletes use HCG for two to three weeks in the middle of their steroid treatment. It is often observed that during this time the athlete makes his best progress with respect to gains in both strength and muscle mass. The reasons for this is clear. On the one hand, by taking HCG the athlete's own testosterone level immediately jumps up and, on the other hand, a large concentration of anabolic substances in the blood is induced by the steroids. Many bodybuilders, powerlifters, and weightlifters report a lower sex drive at the end of a difficult workout cycle, immediately before or after a competition, and especially toward the end of a steroid treatment. Athletes who have often taken steroids in the past usually accept this fact since they know that it is a temporary condition. Those, however who are on the juice all year round, who might suffer psychological consequences or who would perhaps risk the breakup of a relationship because of this should consider this drawback when taking HCG in regular intervals. A reduced libido and spermatogenesis due to steroids in most cases, can be successfully cured by treatment with HCG.
well said haha
Originally posted by jj_tv View PostSo then I should follow up with clomid after? Ok so I want you guys to read this and give me your opinion is this true or false? Cuz I I'm translating it is that you can use it as pct but not trying to argue just want to know if my reference is bad and get some honest opinions, I have clomid and will use it if need be.
