Sdrol PCT Must haves
  • Sdrol PCT Must haves
    Hey guys, wanna start my first Sdrol Cycle, im 27 years old.
    What products do I need for a perfect PCT - the duration of it and the optimal dosage?
    Have read lot about Nolva/Clom,Arimidex, Aromasin and Proviron.
    Help is much appreciated
    Thanks in advance guys!
    If you're running a 4 to 6 week cycle of just oral superdrol, you can run either 4 weeks of Nolvadex or Clomid; both will do the same thing.
    You will want to start the day after you quit the superdrol and will want to run one week of Nolva at 40 mg, weeks two and three at 20mg, and the last week at 10 mg. If you'd rather do Clomid, you can run 100 mg for week 1, 50 mg for week two and three, and 25 mg for week four.
    Arimadex and aromasin are aromatase inhibitors, they help to keep certain compounds while on cycle from converting into estrogen, those are to be taken on cycle. I've never needed an aromatase inhibitor for superdrol, but I have heard of people getting slight gyno so you might want to have some adex on hand.
      Oh, and proviron is an actual steroid that has a unique ability of suppressing estrogen, some guys have good luck running proviron and not needing an AI. You don't want to use it as a PCT though, seeings that it is a steroid.
        I want to run 3 Weeks Sdrol 10/20/20.
        How much aromasin and arimidex/proviron should I take? Im really afraid of gyno thats why I ask that much ^^
          Get some adex and if you get a tickling/sore feeling in your nipples, start with .25 adex eod, if tickling doesnt stop raise to .5 eod.
          Greetz
            ok thanks for the Information.
            Is it true better to run Sdrol with Testo E 250?
            or is oral only cycle possible? what could be negative running it only oral?
              Quite a few orals like Superdrol, Anadrol, and Dianobol work well as kick starts to cycles. They give great strength and due to water retention they help to put on decent weight really fast. The down side is of course is possible liver stress, so thats why you only cycle them for a few weeks; and a portion of the size and strength they give you goes away pretty quick after you stop taking them (that varies for everyone). Test is typically the base for any true cycle and E will take around 4 weeks to start kicking in, so the orals help to give you a kick start.
              I don't think there is anything wrong with an oral cycle, you should just stick to one, maybe two compounds depending on toxicity, for a short period of time. You just will never ever ever get the quality gains from an oral only cycle that you would get from an oil based cycle.
              As far as taking test E; test is the base for any true cycle. You always run test.
                well ok. Problem is injecting things like Testo E.... don't know how to do it and a little fear of it cuz of accidents.
                I'm injecting several other stuff (like MT2, IGF,MOD GRF etc.) subq... without any problem... never injected into a muscle so far.
                is there any good guide how to do a right testo e inject? otherwise I'll have to ask a nurse
                  just go online and search for testosterone injections, there are so many videos on how to do it. also i am currently halfway into week 3 of GP superdrol 20mg + GP oral tren 500mcg and havnt had any noticeable strength gains! no sides either, i'm on .25mg of l-dex EOD and my weight has been going up but thats only b/c i've upped my calories when i started the cycle. Im currently on Test Cyp 400mg per week atm too and will switch from the orals(still havnt kicked in or bunk) to Tren Ace at week 5. I dont think i will be buying GP orals anymore
                  NapsGear.Net - The Largest and Most Trusted!
                    why did you not get any strenght gains? that sounds wreid?
                    Isn't GP a good manufacturer?
                    my sdrol is from other site... I just want to get Testo from GP, is it recommend?
                      some people are telling me on this site that it takes a full 3+ weeks or more to kick in.... which is kind of pointless to me as a "kickstarter" to a cycle..... It could also be bunk, there are other threads on here about people taking 5+ pills a day and getting no results or saying its super underdosed. Those people that i've spoke to, we have the same batch number so it might just be this batch? My batch # for GP Superdrol is GP385F. The GP Oral Tren is GP373F. Which brand of Superdrol did u go with? and let us know how it goes!
                        Can I Tell you here from which supplier I purchased? Or is this not allowed?
                        Otherwise send me PM.
                        What about PCT Stuff? Is this working as intended? Like nolvadex, aromasin etc?
                          ya but i buy AI/PCT in liquid form inside the U.S. you can buy it legally as a "research chemical"
                            GP T-Bol - insane
                              I bought my Sdrol from JW supps
