HCG ? Unraveled
  • HCG ? Unraveled
    by Eric Potratz of Primordial Performance
    Post-Cycle-Therapy is a must upon cessation of steroid use. Many great Post Cycle Therapy protocols have been outlined over the years, and many individuals have had success with following such protocols. Nevertheless, what works can always work better, and I intend to show you the most effective way to recover from AAS. This is especially the case for those that have had a lack of success following popular advice. In this article I will address the misunderstanding and misuse of Human Chorionic Gonadotropin (hCG) and show you the most efficient way to use hCG for the fastest and most complete recovery.
    HCG unraveled –
    Human Chorionic Gonadotropin (hCG) is a peptide hormone that mimics the action of luteinizing hormone (LH). LH is the hormone that stimulates the testes to increase testosterone levels. (1) More specifically LH is the primary signal sent from the pituitary to the testes, which stimulates the leydig cells within the testes to produce testosterone.
    When steroids are administered, LH levels rapidly decline. The absence of an LH signal from the pituitary causes the testes to stop producing testosterone, which causes rapid onset of testicular degeneration. The testicular degeneration begins with a reduction of leydig cell volume, and is then followed by rapid reductions in intra-testicular testosterone (ITT), peroxisomes, and Insulin-like factor 3 (INSL3) – All important bio-markers and factors for proper testicular function and testosterone production. (2-6,19) However, this degeneration can be prevented by a small maintenance dose of hCG ran throughout the cycle. Unfortunately, most steroid users have been engrained to believe that hCG should be used after a cycle, during Post-Cycle-Therapy. Upon reviewing the science and basic endocrinology you will see that a faster and more complete recovery is possible if hCG is ran during a cycle.
    Firstly, we must understand the clinical history of hCG to understand its purpose and its most efficient application. Many popular “steroid profiles” advocate using hCG at a dose of 2500-5000iu once or twice a week. These were the kind of dosages used in the historical (1960′s) hCG studies for hypogonadal men who had reduced testicular sensitivity due to prolonged LH deficiency. (21,22) A prolonged LH deficiency causes the testes to desensitize, requiring a higher hCG dose for ample stimulation. In men with normal LH levels and normal testicular sensitivity, the maximum increase of testosterone is seen from a dose of only 250iu, with minimal increases obtained from 500iu or even 5000iu. (2,11) (It appears the testes maximum secretion of testosterone is about 140% above their normal capacity.) (12-18) If you have allowed your testes to desensitize over the length of a typical steroid cycle, (8-16 weeks) then you would require a higher dose to elicit a response in an attempt to restore normal testicular size and function – but there is cost to this, and a high probability that you won’t regain full testicular function.
    One term that is critical to understand is testosterone secretion capacity which is synonymous to testicular sensitivity. This is the amount of testosterone your testes can produce from any given level of LH or hCG stimulation. Therefore, if you have reduced testosterone secretion capacity (reduced testicular sensitivity), it will take more LH or hCG stimulation to produce the same result as if you had normal testosterone secretion capacity. If you reduce your testosterone secretion capacity too much, then no amount of LH or hCG stimulation will trigger natural testosterone production – and this leads to permanently reduced testosterone production. (recovering full testosterone production is a topic for another article)
    To get an idea of how quickly you can reduce your testosterone secretion capacity from your average steroid cycle, consider this: LH levels are rapidly decreased by the 2nd day of steroid administration. (2,9,10) By shutting down the LH signal and allowing the testis to be non-functional over a 12-16 week period, leydig cell volume decreases 90%, ITT decreases 94%, INSL3 decreases 95%, while the capacity to secrete testosterone decreases as much as 98%. (2-6)
    Note: visually analyzing testes size is a poor method of judging your actual testicular function, since testicular size is not directly related to the ability to secrete testosterone. (4) This is because the leydig cells, which are the primary sites of testosterone secretion, only make up about 10% of the total testicular volume. Therefore, when the testes may only appear 5-10% smaller, the testes ability to secrete testosterone upon LH or hCG stimulation can actually be significantly reduced to 98% of their normal production. (3-5) So do not judge how “shutdown” you are by testicular size!
    The decreased testosterone secretion capacity caused by steroid use was well demonstrated in a study on power athletes who used steroids for 16 weeks, and were then administered 4500iu hCG post cycle. It was found that the steroid users were about 20 times less responsive to hCG, when compared to normal men who did not use steroids. (8) In other words, their testosterone secretion capacity was dramatically reduced because they did not receive an LH signal for 16 weeks. The testes essentially became desensitized and crippled. Case studies with steroid using patients show that aggressive long-term treatment with hCG at dosages as high as 10,000iu E3D for 12 weeks were unable to return full testicular size. (7) Another study with men using low dose steroids for 6 weeks showed unsuccessful return of Insulin-like factor-3 (INSL3) concentration in the testes upon 5000iu/wk of HCG treatment for 12 weeks (6) (INSL3 is an important biomarker for testosterone production potential and sperm production) 20
    In light of the above evidence, it becomes obvious that we must take preventative measures to avoid this testicular degeneration. We must protect our testicular sensitivity. Besides, with hCG being so readily available, and such a painless shot, it makes you wonder why anyone wouldn’t use it on cycle.
    Based on studies with normal men using steroids, 100iu HCG administered everyday was enough to preserve full testicular function and ITT levels, without causing desensitization typically associated with higher doses of hCG. (2) It is important that low-dose hCG is started before testicular sensitivity is reduced, which appears to rapidly manifest within the first 2-3 weeks of steroid use. Also, it’s important to discontinue the hCG before you start Post-Cycle-Therapy so your leydig cells are given a chance to re-sensitize to your body’s own LH production. (To help further enhance testicular sensitivity, the dietary supplement Toco-8 may be used)
    Based off the above information, an optimal dose of hCG during the cycle would be 250iu every 4 days, or as a less desirable alternative, once a week shot of 500iu. Keep in mind, that the half-life of hCG is 3-4 days, while the half-life of LH is only 1-2 hours. Considering this difference in excretion time, it is best to space each dose of hCG at least 4 days apart for the optimal “peak and valley” replication. However, going more than 7 days between each hCG shot may promote increase the rate of desensitization from lack of LH or hCG stimulation.
    If you are starting hCG late in the cycle, one could calculate a rough estimate for their required hCG “kick starting” dosage by multiplying 40iu x days of LH absence. (ie. 40iu x 60 days = 2400iu HCG dose) Remember, since the testes will be desensitized later in a cycle, you will require a higher dose. Also, the maximum daily dose of hCG should not exceed 5000iu, and 4-7 days must be taken off between each shot. Generally, a higher dose will require a longer off period between each shot. (eg., 2500iu = 7 days between each shot)
    Note: If following the on cycle hCG protocol, hCG should NOT be used for PCT.
    Recap -
    For preservation of testicular sensitivity, use 250iu every 4 days starting 14 days after your first AAS dose. At the end of the cycle, drop the hCG two weeks before the AAS clear the system. For example, you would drop hCG about the same time as your last Testosterone Enanthate shot. Or, if you are ending the cycle with orals, you would drop the hCG about 10 days before your last oral dose. This will allow for a sudden and even clearance in hormone levels. This will initiate a strong LH and FSH surge from the pituitary, to begin stimulating your testes to produce testosterone. Remember, recovery doesn’t begin until you are off hCG since your body will not release its own LH until the hCG has cleared the system.
    In conclusion, we have learned that utilizing hCG during a steroid cycle will significantly prevent testicular degeneration. This helps create a seamless transition from “on cycle” to “off cycle” thus avoiding the post cycle crash.
    References -
    1. Glycoprotein hormones: structure and function.
    Pierce JG, Parsons TF 1981
    Annu Rev Biochem 50:466-495
    2. Low-Dose Human Chorionic Gonadotropin Maintains Intratesticular Testosterone in Normal Men with Testosterone-Induced Gonadotropin Suppression
    Andrea D. Coviello, et al
    J. Clin. Endocrinol. Metab., May 2005; 90: 2595 ? 2602.
    3. Luteinizing hormone on Leydig cell structure and function.
    Mendis-Handagama SM
    Histol Histopathol 12:869-882 (1997)
    4. Leydig cell peroxisomes and sterol carrier protein-2 in luteinizing hormone-deprived rats
    SM Mendis-Handagama, et al.
    Endocrinology, Dec 1992; 131: 2839.
    5. Effect of long term deprivation of luteinizing hormone on Leydig cell volume, Leydig cell number, and steroidogenic capacity of the rat testis.
    Keeney DS, et al.
    Endocrinology 1988; 123:2906-2915.
    6.The Effects of Gonadotropin Suppression and Selective Replacement on Insulin-Like Factor 3 Secretion in Normal Adult Men
    Katrine Bay, et al
    J. Clin. Endocrinol. Metab., Mar 2006; 91: 1108 ? 1111.
    7. Successful treatment of anabolic steroid-induced azoospermia with human
    chorionic gonadotropin and human menopausal gonadotropin
    Dev Kumar Menon, et al.
    FERTILITY AND STERILITY VOL. 79, SUPPL. 3, JUNE 2003
    8. Testicular responsiveness to human chorionic godadotrophin during transient hypogonadotrophic hypogonadism induced by androgenic/anabolic steroids in power athletes
    Hannu et al.
    J. Steroid Biochem. Vol. 25, No. 1 pp. 109-112 (1986)
    9. Comparison of testosterone, dihydrotestosterone, luteinizing hormone, and follicle-stimulating hormone in serum after injection of testosterone enanthate of testosterone cypionate.
    Schulte-Beerbuhl M, et al 1980
    Fertil Steril 33:201-203
    10. Effects of chronic testosterone administration in normal men: safety and efficacy of high dosage testosterone and parallel dose-dependent suppression of luteinizing hormone, follicle-stimulating hormone, and sperm production.
    Matsumoto AM, et al 1990
    J Clin Endocrinol Metab 70:282-287
    11. Effect of human chorionic gonadotropin on plasma steroid levels in young and old men.
    Longcope C et al
    Steroids 21:583-590 (1973)
    12. Regulation of peptide hormone receptors and gonadal steroidogenesis.
    Catt KJ, et al
    Rec Prog Horm Res 1980; 36:557-622
    13. Effect of human chorionic gonadotropin on the endocrine function of Papio testes
    GV Katsiia, et al
    Probl Endokrinol (Mosk), Sep 1984; 30(5): 68-71.
    14. Reproductive function in young fathers and grandfathers.
    Nieschlag E, et al.
    J Clin Endocrinol Metab 55:676-681 (1982)
    15. The aging Leydig cell III Gonadotropin stimulation in men.
    Nankin HR, et al. 1981
    J Androl 2:181-189
    16. Reproductive hormones in aging men. I. Measurement of sex steroids, basal luteinizing hormone, and Leydig cell response to human chorionic gonadotropin.
    Harman SM, et al. 1980
    J Clin Endocrinol Metab 51:35-40
    17. Prolonged biphasic response of plasma testosterone to single intramuscular injections of human chorionic gonadotropin.
    Padron RS, et al. 1980
    J Clin Endocrinol Metab 50:1100-1104
    18. Gonadotrophins and plasma testosterone in senescence. In: James VHT, Serio M, Martini L, eds. The endocrine function of the human testis.
    Mazzi C, et al. 1974
    New York: Academic Press, Inc.; 51-66
    19. Androgen biosynthesis in Leydig cells after testicular desensitization by luteinizing hormone-releasing hormone and human chorionic gonadotropin.
    Dufau ML, et al.
    Endocrinology 105 1314-1321 (1979)
    20. Insulin-Like Factor 3 Serum Levels in 135 Normal Men and 85 Men with Testicular Disorders: Relationship to the Luteinizing Hormone-Testosterone Axis
    K. Bay, S. et al
    J. Clin. Endocrinol. Metab., Jun 2005; 90: 3410 ? 3418.
    21. Stimulation of sperm production by human chorionic gonadotropin after prolonged gonadotropin suppression in normal men.
    Matsumoto AM, et al 1985
    J Androl 6:137-143
    22. Human chorionic gonadotropin and testicular function: stimulation of testosterone, testosterone precursors, and sperm production despite high estradiol levels.
    Matsumoto AM, et al. 1983
    J Clin Endocrinol Metab 56:720-728
      WOW!!! Great post. That answered a shit load of questions.
        So how would 1 space out a 5000iu amp of hcg to restore testicular size? I did 500iu 2day so I've got 4500 left. Jus need pointed in the right direction and don't wana waste it. Awesome post bro thanx ipen
          From what I read, if you are going to take 500 iu inj then it would be every 7 days. If you do 250 iu then every 4 days. 250 iu every 4 days being the optimal one to do since it clears the body in that amount of time.
          MODERN DAY GUNSLINGER
            At 250 iu every 4 days, it should last you 80 days. 500 iu every 7 days should last you 70 days. However that brings into question what is the mixed shelf life of HCG when mixed in bacteriostatic water? I thought in had read 60 days but somewhere else read 90 days? Thoughts?
              So can u go the whol cycle at 500iu a week or do u need 2 take breaks every few weeks.
                I'm taking 250 iu every 4 days for my whole cycle. The research ive seen seems to point to this being the best way. I'm just not buying into going your whole cycle with nothing, letting everything shut completely down then trying to jump start it with mega doses at the end when you can keep your nuts from shutting completely off if you take a small maintenance dose throughout. To me, that's like doing no cardio at all for 11 months then try and do cardio 8 hours a day for 1 month. Just doesn't seem logical. Although I'm pretty sure I'm a total idiot so I could completely wrong. Just saying.......
                  DURING CYCLE -from what I have read (including above article) their is no significant benefit in using more than 270 iu's per week for the average AAS user (yes take it whole cycle up to 3or 4 days b4 starting PCT) their also seems to be no negatives to taking more than 270iu's. (u can break it up 2xwk or 1xwk). Some recommend a final booster shot of 1000iu's for last HCG shot.
                  But if u r a long term or high dosage AAS user u may need 500iu-1000iu or even 1500iu's per week to keep the boys @ work.
                  If u take during cycle do not take during PCT.
                  Using HCG in PCT is a different story (use above math equation in article).
                    Great post man,I had been told to do 500ius twice a week all cycle,but if there is no extra benefit I'll stick to 250iu twice a week thanx bro
                      Doesnt HCG break down chemically 11 days after mixing? I went through a doctor and pharmacy to get my hcg and the literture and doc said its no good 11 days after mixing. So I try to use the 5k iu amp in that eleven days.
                        You need to reconstitute it with Bacteriostatic Water, and keep it refrigerated. The solution that comes with the hcg is generally sodium chloride, which will not last long.
                          Thank you so much, I have learned from my mistakes and will make changes. I would be lost without you guys.
