Rest Pause Training
Written By Mike Mahler
Go to any gym these days and you see most trainees doing an endless number of reps all in the hopes of attaining the oh-so elusive and fleetingly short pump. Blame it on Arnold who, years ago in the movie "Pumping Iron," said that getting a pump was as good as coming, or, in Arnold-ese, comink. Ha!
Regardless, going hard and heavy seems to be a part of some distant past as most people these days think that squat racks are a convenient place to do barbell curls. To make matters worse, many gyms have become magnets for meaningless conversations and look more like places for people to hook up then for serious training to take place.
I'm not sure what's worse, the meaningless conversations or the pseudo lifters that attempt to look serious by growling and grunting with each high-rep set and then browse through the newspaper between each worthless set.
Mind you, I'm not saying that high reps are a waste of time. High-rep programs such as the "Super Squats" program produce incredible results and I often do high-rep ballistic sets for high-octane fat burning. However, a very effective and forgotten way to get much stronger and bigger is to do several sets of low reps with short rest periods. One form of this training philosophy is called rest-pause training.
Rest-pause training will separate the serious lifter from the pseudo lifter in no time, as you don't have time to mess around between each set. In additon, this form of training is super intense and requires your full attention.
Bodybuilders during Arnold's competition days used to do rest-pause training from time to time, to get bigger and harder physiques. Mike Mentzer had incredible results with rest-pause training and found it to be an effective way to blast through training plateaus.
Unlike a standard powerlifting routine where you do low reps (1-3 reps) for several sets with long rest periods (3-5 minutes), rest-pause training requires you to take 10-15 second breaks between each set. You're basically taking a short break between each rep in order to use the maximum amount of weight. Since the breaks are short and the weights are heavy, hypertrophy will follow like a charm.
As effective as rest pause training is, it can also be extremely difficult to break into. After all, most people will have trouble taking their one-rep max on the bench press and doing it every 10-15 seconds for 5-6 sets. Chances are they won't get past the second set and will most likely be lucky if they even get that far.
