Baking crystallized gear
  • Baking crystallized gear
    BAKING CRYSTALLIZED GEAR
    Just thought I would post this up since there has been recent talk of crystallized gear and everyone today seems to use the boiling water in a pan method.Some ive heard have not had too much luck with this method.Back in the day we used to bake our crashed gear and it worked every time.Here's how you do it.............
    First vent the vial with a pin and make sure the needle is not in the oil so you dont risk boiling out the gear.
    Than bake it in the oven for about 15 minutes at 225 degrees.
    Take out the vial and swirl it around gently for a bit and then bake it for another 10-15 minutes.
    Remove it from the oven,let it cool and bingo.............GOOD AS NEW!!
    Hope this helps some of you out.It seems to be a forgotten way of bringing your gear back to life but I swear by it on the most crashed gear.
    Thanks Brother, I have
    TNE, Dbol and Drol mix that did not come back with the hot water fix. I will try yhis way and keep you posted
      You're very welcome parabellum666.Ive used this method many times and have always has success.
      Please do keep me posted.
